Question about HP LaserJet 2605dn Printer
HP LaserJet 2605dn Printer - Won't print anything while
Hey Guys.
I have problems with the HP Laser 2605dn, it doesnt print as it kept sayin "printing Document" with green light flashing.
when ever i send print doc from word or anything it still kept sayin "printing document"
and when i tryed to demo printing still not doing anything
could you tell me what is wrong with it and how do i solve the problems to make it working
please help me
from Bhav cheers.
  • 1 more comment
  • chuprym Jan 29, 2009
    i have the same problem!!! i have a document, go to file and print. it says that it is printing on my computer and on the printer. it blinks that its printing, but nothing comes out!! it just blinks and says "printing". i contacted HP and they did not help me! did you resolve your problem?
  • pgibbsgbr Mar 17, 2009
    I have the same problem exactly, my printer worked fine, changed cartridges it printed once and then stopped printing, flashing green light but nothing happening.
  • prem_kmani Apr 09, 2009
    supply error
  • 32 Answers
SOURCE: HP 2605dn- replaced all toner cartridges now it won't print-
There might be a problem with the network connection. Is the cable connected to the back of the printer?
The printer could have lost the connection.
If the printer is able to print a configuration page and if the display responds to comands from the buttons in the display panel there is a very good chance the network connection was lost.
Yo mentioned "paper jam" is the printer identifying a paper jam?
Posted on Nov 19, 2008
  • 2692 Answers
SOURCE: HP Laser jet 2605dn and Vista
   You must download and install the VISTA driver.    HP Link provided:
Posted on Feb 25, 2009
  • 2120 Answers
SOURCE: HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Posted on Feb 26, 2009
SOURCE: HP Laser 2200 Cannot print one page or a range from a document
I think the problem is in the printer setting, so just uninstall the Printer(Driver). Restart the PC and reinstall the driver.
It may solve your problem.
Rakesh Kumar
Posted on Apr 09, 2009
  • 10 Answers
SOURCE: while printing documents in Hp LaserJet 1020,
you shuld disable the " print the event log " in your driver in control panel
Posted on Jun 23, 2009
Hp color laser jet 2605dn gives me a message printing document but does not continue print it then tels me to turn of printer and turn it back on
According to your problem, The instruction is correct.First remove all pending print job from print queue by double click on printer in printers and faxes wizard. Then reboot the printer and system both. After turn on give a print job. If it doesn't help you then check the page setup in printer properties.
Apr 28, 2011 | HP LaserJet 2605dn Printer
My hp 2605dn doesn't print red very dark even though the toner cartridge is full
The 2600's and 2605's share the same problem.
The scanner has to be removed and cleaned because magenta toner builds up on the laser scanner mirror.
You need a service manual.
Aug 11, 2010 | HP Hewlett Packard LaserJet 2605dn Printer
�Hp laserjet 1600 red color print out very low (new cartridge)
- the problem might be with the laser/scanner assembly of the printer, it is probably dirty
- refer to an HP Authorized Service Provider to solve the problem
Aug 01, 2010 | HP LaserJet 1600 Printer
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
May 17, 2010 | HP LaserJet 2605dn Printer
HP 2605dn printing pale on magenta
This is likley to be the common problem (with this model of printer) of the laser unit having dirty lenes and/or mirrors.
Typically the magenta is the first colour to deteriorate.
To rectify this problem there's a fair bit of dismantling to be done in order to get the laser unit out.
Then you can open the laser unit up and clean the lenses and mirrors CAREFULLY. You don't want to scratch the surface silvered mirrors, or disturb the alignment of any of the optical components.
You'll see the same problem and solution for HP1600, HP2600, and Canon LBP5000, as they all use the same laser unit.
Feb 09, 2010 | HP LaserJet 2605dn Printer
When I print colour prints on my HP 2605DN the red ink is always missing although there is plenty of toner left. This problem started about a year ago and it got gradually worse. Now there is no red ink...
This is known as laser scanner contamination and it simply needs to be serviced, they will clean some mirrors on the laser which are impeding the light from making contact with the magenta toner, therefore not using it.
Jan 22, 2010 | HP LaserJet 2605dn Printer
This is a common problem on these printers.
Cause is dirty lenses and or mirrors in the laser unit.
Solution is remove laser unit, open it, clean lenses and mirrors (very carefully to avoid disturbing alignments, and scratching).
The laser unit is deep in the printer, so it's quite a lot of work, but very rewarding when you've fixed it.
Alternatives - buy a replacement laser unit and swap and clean old one at leisure, or get an exchange refurb printer - if you think your mechanical skills arn't up to it.
Jan 18, 2010 | HP Hewlett Packard LaserJet 2605dn Printer
When I print colour prints on my HP 2605DN the red ink is always missing although there is plenty of toner left. This problem started about a year after I bought the printer and it got gradually worse. Now...
Probably a dirty laser unit.
It's cleanable (but you need to take care
1 not to scratch any of the surface silvered mirrors.
2 not to disturb the alignment of any of the optical components.
It's quite a bit of dismantling (you start from the back of the printer and work your way 'into' it until you get to the laser unit). Youcan then remove the laser unit, open it up and clean it.
Dec 03, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
Hp hewlet packard laser jet 2605dn printer is printing an extra blank page
This can be a status report sheet or else check the settings of the printer from the control panel / printers in the printers' settings.
Mar 02, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
Printer says printing document but will not print. anything
I had this same problem, and after 45 minutes with HP support, eventually managed to get it to print by turning the printer of and then holding down both arrow keys (left and right) at the same time while turning the printer back on. I held down the arrow keys until it said "Language: English" and then clicked through the prompts. It then restarted, and all was well again.
Other places mention doing this with the OK and Cancel keys, but that didn't do it for me - the arrow keys did.
Jun 24, 2008 | HP LaserJet 2605dn Printer
227 people viewed this question
Ben Johnson
