Question about Sony RDR-GX355
Command codes I accidentally switched my command code from dvd3 to dvd1 and now i am locked out of the player completely. it just keeps flashing dvd1 on the screen and thats it. How do I fix this? I saw directons to a page but I believe that page has been deleted. I think the premise was the problem was the command code for the remote. Ok....how do I change the command code on my remote to get the dvd recorder to start working again. Thank you very much in advance, James
    Genius:
  • 2,035 Answers
Try to reset the player :You can also try a hard reset: Unplug unit from AC mains and remove all cables from unit. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the unit and see if it works..if this fails then you need Restart the recorder Press down power switch for more than 10 seconds until Sony DVD appears this will set to default factory setting in the player.....
Posted on Sep 22, 2008
    President:
  • 1,952 Answers
Go to this web page and check page 23 for instructions on setting the remotes command mode, you will want to set it to 1. http://129.33.22.12/release/RDRGX355.pdf
I accidentally changed the command code from dvd3 to dvd1 and now my remote doesn't work, and I don't know how to access the systems menu to change it back.
Since unit has been set on DVD1 remote mode so you need to set remote control itself on dvd1 mode to communicate with unit.
Press and hold Enter and 1 numeric key on remote control for 5 seconds, this will change remote control to dvd1 mode, now unit will accept remote control signal and you can operate it normally.
Thanks.
Jan 02, 2011 | Sony RDR-VX535 Player
Dvd recorder
The following should give you access to a service menu containing controls for macro-vision and region coding. You can change the regional settings from there.
1. Set your player to Standby
2. Press Title, Clear and Power
Jul 05, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Sony dvd recorder rdr-gxd310
Click here to get the user guide and go to page # 21.
May 23, 2008 | Televison & Video
I can't return to command mode dvd3 (default) from dvd1. Now my remote is useless and I can't find a way to bring up the main menu so I can get back into command mode dvd3.
Slide remote lower cover and look for DVD Command mode set switch, set it to DVD-3 position, your RDR-VX530 will accept remote commands.
Thanks.
Dec 21, 2010 | Sony RDR-VX530 DVD Recorder/VCR
I have a Sony RDR-VX560 DVD Recorder / VCR Combo, accidentally put it to dvd1 instead of dvd3...ive tried holding the enter button and all that and nothin works..any way to get factory reset or any help?
Hold down Enter button on remote and while holding Enter press and hold 1 (numeric) on remote for 3 or 4 seconds, now remote is set on dvd1 mode and dvd recorder will accept its commands.
Thanks.
Mar 19, 2010 | Sony RDR-VX560 DVD Recorder/VCR
Set up sony RDR-VX535 recorder to DVD1. now remote does not work.
See the manual on page 22.
The solution is to reset your remote code to DVD1 (default is DVD3).
Press the ENTER button and NUMBER ONE button simultaneously for at least three seconds. Viola, control returns.
Feb 22, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Command codes
Read page 23 in the manual.
Press "enter" & the #1 keys together for 5 seconds.
Then press stop.
Press "system menu" & change the option back to dvd3.
Then press "enter" & the #3 keys together for 5 seconds.
Press "system menu".
Or call Sony Main Support # 1-800-488-7669
Mar 07, 2008 | Sony RDR-GX355
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Sony RDR-GX355 Logo
285 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
