Samsung HP-P4261 42 in. HDTV-Ready Plasma Television Logo
A
Anonymous Posted on Oct 14, 2011
Won't power up - Samsung HP-P4261 42 in. HDTV-Ready Plasma Television
2000 miata will crank over but fuel pump won't pump
Relay, on top of fuel tank under parcel shelf, check its getting power, if not its fuse, if it is, bin it get a new one.
1helpful
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
When you push start button nothing happens
2helpful
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
1helpful
Shut off won't turn back on
how long have you waited since it shut off? it may be overheating. if you've waited for a while and it still won't power up, you may need to test the power supply. if you don't have a power supply tester and most people don't you can remove it from the case and take it to any pc shop. they may charge you a couple bucks but most shops won't do that. if it's bad it will need replaced obviously, if it's not let us know :)
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
1helpful
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
My woofer is 18' 600w rms power. so what is the
Basically you cannot break you woofer with too powerful amp, but you can break it using too weak amp. This is because if you don't have enough watts going to you woofer the cones movement isn't controlled properly. I'm usually using +20% to the woofers RMS and peak power. This will also make the amp last longer because you won't use it at it's peak performance all the time. If possible use manufacturer whose prising policy matches your woofers manufacturers, that way you won't end up with "2000w peak power" cheap amp with real output of 30w. and in the other end cheap woofer won't handle expensive amp with real 600w rms so well, you need to find a midlle way here. Hard to say without knowing the make and model of the woofer.
This is a taste question for some people, and I haven't build a system to match so powerful woofer ever in my life. But I'm pretty sure you won't go wrong with this one.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
