Question about Sony Video Game Consoles & Games
I cannot set up network connection for PS3 as it keeps coming up with e-mail address and password incorrect
My son sorted problem out Thank You
Mrs Douglas
Posted on Sep 23, 2008
I cannot access my emails in my outlook account on my Toshiba CB50 Laptop it keeps saying theres a problem with my account why is this?
Solution: Make sure that your computer is connected to the Internet or your network. Use a Web browser to see whether you can access Internet sites. If you are on a local network, see whether you can access intranet sites. For information about checking the status of your network connections, see Mac OS Help. Solution: Verify that Outlook is online. On the Outlook menu, make sure that Work Offline is not checked. Cause: Some POP and IMAP e-mail accounts use an outgoing mail (SMTP) server that requires authentication. Solution: Turn on SMTP authentication for the POP or IMAP account. Some e-mail services, including MobileMe mail accounts, require authentication for their SMTP server. If you verify that all your account settings are correct, but you still can't send messages, try turning on SMTP authentication. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. Under Outgoing server, click More Options. On the Authentication pop-up menu, select the authentication type, and then enter your credentials as necessary. Cause: Your ISP or network has a firewall that blocks connections to your e-mail service's outgoing mail (SMTP) server. Solution: See if your ISP or network administrator can provide an alternative SMTP server to use for your POP or IMAP account. If you have the address of an alternative SMTP server, enter it in your account settings. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. In the Outgoing server box, type the server name or address. NOTE: If you use a laptop computer in multiple locations, such as at home and at work, the SMTP server that you use in one location may not work in other locations. Each Internet connection that you use may have a firewall with its own restrictions. Cause: Your credentials or account settings are incorrect. Solution: Verify that your account user name, password, and other settings are correct in Account preferences. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. Make sure that you have entered the correct e-mail address, user name, and password. If your account still does not work properly, check with your e-mail service provider for details about how to configure your account in a mail application. Your account may require that you use special settings such as Secure Sockets Layer (SSL) to connect, or that you override the default port. Cause: Your network requires a proxy server to connect with the mail server. Solution: Specify a mail proxy server in your computer's System Preferences. If you use a network to connect to the Internet, you might have to specify a mail proxy server. Ask your network administrator for the correct settings for your mail proxy server. For instructions about how to enter these settings, see Mac OS Help. Cause: Your e-mail server is unavailable. Solution: Make sure that the mail server is online. If you successfully connected to the account before, the mail server might be offline. Contact your e-mail provider or network administrator to see whether the mail server is available.
Mar 25, 2016 | Toshiba Computers & Internet
Everytime i try to sign on to my PSN or try to play online i keep getting this error code. 80710763 can anyone help me please? i cant seem to find an answer to what it means.
Shawn, I believe this is a network or Router error. The simplest solution would be to wire connect your system using a cat-5 Ethernet cord. If you still have issues connecting to the PSN, then it could be something worse. Try to do a connection test. Go to the XMB(home screen) on your PS3, scroll all the way to the left(Where you would sign in) one space to the right, then all the way to the bottom of the tab. It will say "Network connection" go into that then scroll down to "Test Network" The main thing you are looking for here, are the top 3 items that will display. "Checking for IP address" should say (SUCCESS) "Checking for internet" Should say (SUCCESS) then "Playstation Network(PSN)" again, should say (SUCCESS) If all of these say Success, then the problem is with your log-in information.(E-mail or password incorrect) If they say (FAIL) then you need to contact your internet service provider (ISP). I hope this helps you out. Good luck.
Dec 09, 2014 | Sony Playstation 3 (PS3) Console
Help yahoo com
Symptoms You can try these basic steps to troubleshoot Mail on your iPhone, iPad, or iPod touch. If you see a specific error message, follow the basic steps, then the steps for that error message. For example, you might see one of these messages:
  • Cannot get mail
  • Unable to move message
  • Username or password is incorrect
  • Relaying denied
  • Email address rejected by the server
Resolution First, try these basic troubleshooting steps:
  1. Tap Safari and load a webpage. If you can load a webpage, then your device has Internet access. If you can't load a webpage, check your Wi-Fi connection or try a different Internet connection:
    • Try a different Wi-Fi connection.
    • If your iOS device has an active cellular data plan, tap Settings > Wi-Fi and turn off Wi-Fi.
    • If the affected email account is provided by your Internet provider, see if your issue is resolved while connected to your home Wi-Fi network.*
  2. Log in to your email provider's website to make sure that the account is active and the password is correct.
  3. Make sure your settings are correct using Mail Settings Lookup.
  4. Restart your iOS device.
  5. Delete the affected email account from your device.
    1. Tap Settings > Mail, Contacts, Calendars.
    2. Tap the affected email account.
    3. Tap Delete Account.
    4. Add your account again.
* If you can only use your email account while connected to your home network, this might be a limitation put in place by your email service provider. For help, please contact your email service provider.
Follow the steps below for specific alerts.
"Cannot get mail" Make sure you entered the correct password. If you enabled two-step verification through your email service provider, contact them to see if you need a special password for your iOS device.
"Unable to move message"
  1. Tap Settings > Mail, Contacts, Calendar, then tap your email.
  2. Tap Account.
  3. Tap Advanced.
  4. Tap Deleted Mailbox and make sure it's set to Trash.
  5. Tap Advanced > Account, then tap Done.
    Note: If you see the issue again, repeat steps 1 through 3, tap IMAP Path Prefix, then Inbox. After you make your changes, tap Account, then Done.
"Username or password is incorrect" with POP3 account Before you check your email on your iOS device, close it on your computer and other devices.
To see if your account is a POP3 account use the Mail Settings Lookup tool or:
  1. Go to Settings > Mail, Contacts, Calendars and tap the account.
  2. Look for the label POP ACCOUNT INFORMATION.
If your email provider offers IMAP, remove the POP3 account, then add the account with your provider's IMAP settings. POP3 communicates with one mail client at a time. If more than one mail client tries to connect, you might see a username or password error.
"Relaying denied" or "Email address rejected by the server" when you try to send email This error indicates that either an email address is incorrect or your settings aren't correct for your current connection. Make sure the email address is correct for messages in the Outbox or try a different port:
  • If you're on a Wi-Fi network connected to the same network as your email domain, such as your Cable or DSL provider, try port 25:
    2. Tap your email account, then tap Account.
    3. Scroll down and tap Outgoing Mail Server.
    4. Tap Primary Server, then tap Server Port.
    5. Delete the current port and enter 25.
    6. Tap Done.
  • When you connect to a cellular data or a different Wi-Fi network, you need to use an alternate port and authentication, if your email provider supports it. The most common alternate ports are 465 and 587. Check with your email provider for specific settings.
If you still can't send email, you can set up an alternate SMTP server.
Get help troubleshooting iCloud Mail.
Aug 29, 2014 | Yahoo Mail
Ps3 says ip address timed out / wep key was entered incorrect.
Have you tried manually adding a IP to your PS3 ie if your routers ip address is 192.168.1.254 set your PS3 to 192.168.1.60, with a subnet of 255.255.255.0 and set the gateway to the IP address of your router in this example it would be 192.168.1.254..
May 03, 2017 | Sony Playstation 3 (PS3) Console
It is saying my password and/or e-mail address is incorrect and when i click 'forgot password' it is saying my date of birth is also incorrect, what can i do about this?
Your best bet is to go online to the PSN Network and try there. You'll need to know the date of Birth and the email of the account you need a password for, so hopefully you remember what you chose.
Dec 22, 2010 | Sony Playstation 3 (PS3) Console
How to change email server for imagistics 2520
Open Internet Explorer and type in the IP address of the cm2520 embedded controller.
2. Click Admin Mode; under Administrator Password, type in the default password (12345678) and
click Login.
3. Click Network.
4. Click E-mail.
5. Under E-mail Receive (POP) Configuration, set Receive to Enable.
6. Under Receiving Server Address, type in the IP address of the POP3 server.
7. Under Username and Password, type in the Username and Password given to the copier by the
network administrator.
8. Leave APOP authentication at Disable.
9. Leave Connection Timeout and Port Number at the default setting.
10. Click Apply, then O.K.
11. Click E-mail Transmission.
12. Set Transmission to Enable.
13. Under SMTP Server Address, type in the IP address of the SMTP server address.
14. Leave Port Number at the default (25).
15. Set Connection Time-out to 60 seconds.
Sep 21, 2010 | OCE Office Equipment & Supplies
Hello, can you help, on my ps3 it keeps coming up with error 80710102 and will not connect to the internet or find the wireless box
This is a common dns error with playstation.
try entering the following in your ps3. Settings - Network Settings - internet connection settings - custom - wired or wireless depending on your internet - manual settings - IP address manual - enter your ip address and your router address and change your dns primary
Mar 17, 2010 | Sony Playstation 3 (PS3) Console
I keep put my pass word response comes back incorrect info. and i know its correct because my daughter gave it to me..... please help.
goto the link below and enter your e-mail address and they will mail you the user-id and password.
http://www.facebook.com/reset.php
Peace,
B
Jun 26, 2009 | Facebook Social Network
Video Game Consoles & Games Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
