Question about Gateway M305CRV Notebook
Black screen my gateway laptop boots up, but it has a black screen. i can see a slight image on the screen. i did connect it to a desktop monitor and i had to boot up in safe mode to see anything from the laptop. helpppp please.
  • 2 more comments
  • unutewan Oct 15, 2008
    i have the same problem, my M305CRV is not working also. I'm looking for help in this matter. if you have the solution pls, let me know or posted so i can have it running again. m so desperate.....
  • jkiggs Oct 16, 2008
    I have the same problem any help is really appreciated!
  • jbanning3 Nov 03, 2008
    When I turn on my computer sometimes the screen goes black. I can barely see anything on the screen. If I put the screen down then lift it and hold it just right it might stay on for awhile.
  • jltodd Dec 06, 2008
    I didn't see any solutions to this problem. Where do I get the solutions? There were supposed to be two.
Thanks it's working but the display is blurry.... how do i make the screen brighter.... i have the brightness button on the keyboard but it's not working.... is there any way to fix this in the computer itself.
Posted on Oct 21, 2008
When i connect an external monitor and use Fn+F3 i was able to see the computer so i guess either the backlight or the inverter is not functional
Posted on Oct 20, 2008
  • jkiggs Oct 20, 2008
    Solution at last! if you connect the laptop to an external monitor and press(Fn + F3) does it work? then what you have is a backlight Inverter problem which in this case is broken (this boosts the electrical voltage level ) it retails on the web for about $70.
    regards,
    Jkiggs
How do I replace the f1 fuse in my gateway 7326
Will it boot? Fan spin? LED's blink? Sound? Try connecting to a external monitor, does it show desktop? The screen is all black, no cursor at top left? No "ghost Image" in the screen when viewed in a bright light? I would look at the inverter board, backlighting, ribbon cable in the rear of the monitor, the LCD screen, your laptop has some miles on it. Not sure about a fuse on a laptop motherboard, don't see that often. Take a look at this may help you troubleshoot: http://www.youtube.com/watch?v=2Yi6GNFcP3w
ALSO Gateway Support may help: https://support.gateway.com/s/Mobile/Gateway/7305GZ/4694nv.shtml
Feb 08, 2013 | Gateway Computers & Internet
I have a gateway tablet m285e. The problem is, it boots up to a black screen. F8 does nothing, trying to use a boot disk does nothing. I connected another monitor to it and still black screen. It does...
If you connect to external monitor and don`t work
Try:
1.- Remove the memory module and clean the gold connectors
reseat the memory.
If continue don`t show image
Disassembly the laptop
Remove the processor
and reseat again
If don`t work, is your Chipset video
Maybe you can try fix the chipset video
look solutions like
http://www.youtube.com/watch?v=BLNReuT67p8
apply heat to Chipset video.
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Gateway M285-E Notebook
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps you get back going.
BuddyMc
Sep 20, 2011 | Gateway FPD1975W 19" LCD Monitor
My gateway MT6919 comes to a blackscreen when i turn it on. I have replaced the motherboard. Still a black screen. I replaced the invertor and still a blackscreen. I'm not sure what to try next I...
You could have a faulty CCFL lamp that provides the back light.
If you view the LCD screen at a sharp angle and you can see a dim Windows image. Also if you connect an external monitor to the laptops VGA port power up the external monitor then boot up the laptop and you get a normal Windows image on the monitor, then it is a faulty CCFL lamp.
Replacement CCFL lamps are available from this WEB site.
www.lcdparts.net
Jul 14, 2011 | Gateway MT6919 Laptop Charger...
Blank screen
Try plugging the laptop into an external monitor to make sure the laptop is booting up properly. If it is unplug the monitor from the laptop; or if you know the laptop boots up fine and you get the windows audio when it boots and the initial starting beeps then forget the monitor. Shine a torch or light source on the screen and if you see a faint picture then the inverter on the screen has developed a fault.
jon
Nov 04, 2009 | Gateway ONE GZ7108 All-in-One Desktop PC
My laptop doesn't boot up. Only get a black screen.
have you tried connecting to an external monitor?
Oct 15, 2009 | Gateway M285-E Notebook
Gateway 2" monitor won't display
blown capacitors this can be fixed I can help or advise you how to do it but it will require soldering internal components.
Mar 04, 2009 | Gateway FPD2275W LCD Monitor
Gateway 450sx4
Yes you should try ito adjust the brightness.
Can you see a slight image on the LCD, screen this indicates a backlight problem?
You can connect an external monitor to the video connector on the laptop, then boot it up and see if the is a display on the external monitor. You may have to press the blue Fn + one of the Function key so you can switch the video output to the external monitor. If you get an image on the external monitor then the video card is OK and the fault is with the LCD backlight. This could be a faulty inverter that supplies high voltage to the CCFL lamp or the CCFL lamp is faulty, 80% of the time it is the CCFL lamp that is faulty.
The inverter is easy to replace, the CCFL lamp requires a lot more work and requires soldering skills.
Go to www.lcdparts.net for parts and/or repair service and DIY info.
Mar 03, 2009 | Gateway 450SX4 Notebook
Gateway laptop 450 rog
be sure to circle through possible screen.
use FN key + a key with a screen symbol on your keyboard (or check your doc) to switch from main screen to external monitor and back.
sometime some techies use external monitor for pc final test and forgot to restore configuration to laptop screen.
At restart XP is expecting the last used monitor and nothing shows on laptop screen.
try also connecting any external monitor to vga plug.
let me know if is fixing
Jan 04, 2009 | Computers & Internet
Gateway M305CRV Notebook Logo
250 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
