I have power to my washer. I get no response to the touchpad however after disconnecting and reconnecting connectors on control board I get aq power failure error then I am able to start the washer. It will run for a few minutes then go dead and not restart. where can I look or test for voltages to find trouble and fix this board? The machine is a Kenmore elite washer.
    Sergeant:
  • 399 Answers
    Genius:
  • 1,550 Answers
CAN YOU BE SPECIFIC WITH YOUR MODEL NUMBER
SO THAT WE CAN BE SPECIFIC WITH YOUR MODEL
Thanks for using Fixya
Posted on Sep 22, 2008
2 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: control board problem
please provide the brand and model number so I can help you..
Posted on Sep 23, 2008
What does eroor E6 Mean
The E6-F2 error code indicates a problem with the touchpad or the electronic oven control. E6-F2 specifically means the cancel key drive line is open. You can't cancel this error code, but sometimes removing the power from the oven and reconnecting it will cure it.This is usually a fault in the touchpad, but can also be caused by the electronic oven control. To test the oven you would need to remove the control panel and disconnect the ribbon connector from the touchpad to the oven control at the oven control. Clean the end of the ribbon and reconnect it. This will sometimes correct the problem by curing a weak connection. If the error code comes back you should replace the control panel which contains the touchpad. 8300427- black
8300428- white
8300516- biscuit
The part number for the electronic oven control is 8302319.
Apr 29, 2014 | Heating & Cooling
Kenmore Elite Oasis top load has a code of F 71?
F71 is no communication detected from the User Interface to the Central Control Unit (CCU). This could simply mean a loose or poor connection between the two communicating boards.
Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Remove the three screws attaching the top panel to the rear of the washer then slide the panel rearward and lift it off the washer.
Disconnect the User Interface ribbon connector from the left side of the Central Control Unit (CCU) and clean the connector and terminals thoroughly. Reseat the connector several times to ensure a good connection between the Central Control Unit (CCU) and the User Interface.
It is highly recommended to clean and reseat every wiring harness connector from the Central Control Unit (CCU) to prevent the same problem in the near future.
Reconnect every wiring harness to the CCU and make sure all connectors are firmly seated. Slide the top panel back into position and secure it to the rear of the washer with the screws previously removed.
Apr 25, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Nothing works on control panel except control locked sensor light. The buttons were working fine then I went to add more drying time and the buttons do not light up or work.
From the details of your symptom you're indicating a possible intermittent loose connection between the user interface (touch panel) and the machine control board or the voltage supply to machine control board at P1 connector.
Disconnect the power cord from the power source.
  • Disconnect P3 and P4 connectors from the machine control board and then reconnect them.
  • Disconnect P1 connector and then reinstall the P1 connector and then recheck operation.
If the wires are good then you will need to replace the control board on your unit.
Here is a link to the part.
Jan 09, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
I keep getting f2
Sorry to read about your problem, I hope this helps you out.
f2 is a defective keyboard/keypad issue, i suggest you contact a service company
Their is nothing you can do to stop the problem.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The unit is a Maytag model MDB5601AWW which it has recently began to lose power at the touch pad. The electrical breaker has been checked to confirm normal voltage. Additional investigation suggests that...
It sounds to me then that the display board or touchpad needs replacing,you havn't said that it's not doing it's cycles.so it's not causing any washing or cycle problems.i would replace the display board.
May 28, 2010 | Dishwashers
Whirlpool duet washer f-06 error
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Mar 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore he2 plus washing
CCU/Touchpad/LED assembly error(f21)
This error occurs if the touchpad/DED assembly is not able to transmit/receive data to/from the central control unit (CCU)
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding 2. Unplug washer or disconnect power for five minutes. this will reset the CCU, and may reactivate the commmunication if the damage isnt sever. 3. Check Wire Harness connectors to the touchpad/LED assembly and Central Control Unit (CCU)
Replace failed component.
Sep 18, 2009 | Washing Machines
The washer is flashing f 21, what does that mean?
F22
2. Unplug washer or disconnect power.
Replace failed component.(In most cases, the CCU(Central Control Unit), will need to be replaced).
Jul 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control board problem
Sep 22, 2008 | Washing Machines
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
