Question about Home
How to identify make and model of old whirlpool tub?
We bought a house with a broken whirlpool tub. When we turn it on, we can hear the motor hum but no air comes out of the jets. The previous owners inherited the tub in the same condition and made no attempt to get it repaired.
The problem I have is, how can I identify who made this tub and what model it is? I think it dates from the 1990s, when the bathroom was supposedly remodeled. But the only clue I have as to its identity is that the drain switch says "Kohler." Looking at Kohler's Web site, though, I can't find a model that looks like this one (this is not a high-end product and I'm guessing it's a cheaper brand that happened to use Kohler hardware).
Is there any kind of Web site that has a database of old models, or is there some secret place in the guts of the tub (I haven't opened the access panel yet) that would contain this info?
Chris
This is a problem common to all whirlpool/air jet style tubs. The pumps become air locked due to the water evaporating from lack of use. All tubs need, and have, SOME means of priming the pump, this is most likely what the problem was, originally, for you. This time in particular you found it to be electrical in nature but for future reference, for you and all who have these style of tubs, I am putting this out there. Some where on the tub, usually along the top edge of the tub is a vent knob that controls the amount of air that the pump is allowed to mix with the water for the jets, usually by closing this valve all the way (tub needs to be full of water of course) and running the pump for a minute or 2, you should be able to get the pump pumping water again, if not you may need to do something else with your particular set-up to get it purged of air, the pumps in jacuzzi tubs are designed to pump water, not air, so if the motor is running but you get no jet action, your most likely air locked and need to prime pump/purge air.
Posted on Jan 24, 2009
    President:
  • 1,263 Answers
I use to work at kohler and my uncle still does he's a production designer so he would know. take a few pictures and e- mail me at rsmlucky32003@yahoo.com and i will get back to you. please rate thanks
Posted on Sep 26, 2008
  • Ronald Mueller
    Ronald Mueller Sep 27, 2008
    you could look in thre panel and there should be a sticker with the info ul rating and serial number,etc
Model lsr5132pq0. Why won't it agitate?
I have an older model (about 15 yrs old) that a similar problem. I turned it on its side thinking it was a broken drive belt. There was no belt because it was a direct drive. I removed the motor and found a white plastic coupling (285753A) that had its teeth broken off. I found the part at a local parts store for about $10.
Dec 31, 2015 | Whirlpool Washing Machines
I have a Neptune air tub and the motor turns on when I press on but the air is not coming out of the jets. The tub does not have an air knob
So you can hear the air blower turn on however there are no little bubbles coming out of the air injectors...
I would have you verify that the blower is blowing air out. Either the hose has come off and it is blowing air under the tub or the fan has disengaged itself from the motor and is not turning.
I will ask you to verify that one of those two things has happened or possibly the check valve in your system is closed and will not open.
US Parts Center
Nov 10, 2013 | Neptune DB60TAM Whirlpools and Air Tubs
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
Jun 30, 2012 | Jacuzzi Fuzion Whirlpool
My Aqua Glass Whirlpool tub has stopped working. The motor comes makes a sound when I turn it on but the jets are not working
Your motor is shot. you need a new pump. If it comes on and you can hear a hum then it is bad. If you can get us a model number of the pump we can recommend a replacement model for you.
US Parts Center
Jan 05, 2011 | Whirlpool Safety Bath Walk In Bathtub -...
Fill tub, press button, hear motor but no bubbles,etc coming from jets
Are the jets open? The center of the jets turn to adjust the pressure of the jets. If this is not the problem, there may be a problem with the impeller in the pump assembly. If you here the pump turning and not buzzing, it could be an air bubble in the suction tube. This tube is the one coming from the front of the pump, if the pump is higher than the tube coming from the tub, or if there is a high spot in the tube, an air bubble is a real possibility. If the tube is level with the pump, there should be no problem with air bubbles and the problem lies in the top part of this paragraph.
Mar 10, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jetted bath tub has stopped working. Motor hums
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
Feb 15, 2010 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Whirlpool electric dryer tub won't turn. Belt is
if you are hearing loud buzzing or loud humming when start switch is engaged,u have 2 possibilities:1. a bad motor. 2.something hindering the motor's ability to turn.most likely cause of this is usually something caught in the blower housing,preventing motor from turning
Nov 12, 2009 | Whirlpool Dryers
I have a whirlpool LP Dryer model #LGR5848E that won't start.
can you turn the drum by hand.
if not i would be concerned that you have a sock or something stuck in the blower sqiral cage.
if you can turn it by hand and it sspins freely, then you may have several issues, broken belt, is where id start,
the fact that you can hear a hum say the motor is trying
Oct 05, 2009 | Whirlpool Dryers
It won't run. I hear the humming but it won't turn. It fills up but won't wash.
you probably just have a broken belt. If it doesn't ever move the tub but you hear the motor running this is likely to be the problem.
Sep 07, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Home Logo
4,499 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
