Question about Memorex MLT3221 32 in. LCD TV
Two vertical line in the screen???
I have two vertical lines in the screen on all channels, any idea what the cause and how to fix that.
thank you
  • 4 more comments
  • charmouta Sep 23, 2008
    ok in more details if i go to normal TV channel i get a blue since no cable is attached, i only get one balck line, if i hit the menu than the blakc line turn to yellow and i get a blue and a red line to the left only visible on the menu the rest of teh screen is still solid blue except for where the black line is.
    ok i had the TV unpluged from everything since yesterday and did not work, i unplugged waited 30 min nad changed cables and still have lines.
    i have not received another solution to the problem, the first solution did not work.
  • charmouta Sep 24, 2008
    are you saying one if the cable is bad or has a bad connection. can you tell me which cable i can check it for that problem.
    well since this one did not go anywhere can you help with this:
    I was updating the TV Software and now it is stuck on that screen, no matter what I do I can?t get off that screen even if I unplug it and plug back in the TV comes on by itself to that screen only.
    Is there anyway to reset it somehow back to original? Or do you have any other solution?
    I called Philips and they a tech need to service it no help there.
    Thank you
    I was updating the TV Software on 32PFL7332D and now it is stuck on that screen, no matter what I do I can?t get off that screen even if I unplug it and plug back in the TV comes on by itself to that screen only.
    Thank you
  • Memorex Master
  • 1,800 Answers
For that philips try to update it software again cuz that one is not in the same version of the old one or maybe its a problem with the flash memry that got the software in side the borad u can change that part if it is the faulty but its up to ur soldering skill and using te hot air kit.
be careful for any shock give me the borad number and good rate to give u the neatest one to give that part!!
best regards
Posted on Sep 24, 2008
    Scholar:
  • 152 Answers
Since the LCD screen changes color as the liquid crystals respond when a charge is applied to the tiny transistors, the two vertical lines on the screen means that no electricity is passing through those lines. The problem, therefore, could be traced to the specific connection interface in that line of the LCD panel. Simply put, the problem is traceable to the wirings that supply electricity to the panel.
  • 59 Answers
You have to take it back unless you want to void the warranty and have a nice paperweight. it's a manufacturer defect or error sorry chum
  • 10,594 Answers
Its LCD panel problem and calls x-tap-bond lose joints.
Not possible to repair in repair shop.
Please ask Memorex Customer Support for repair of LCD Panel.
Thank you.
Posted on Sep 23, 2008
  • Shahid Electronics
    Shahid Electronics Sep 24, 2008
    Please call Memorex Customer Support on above web link numbers
  • 2,322 Answers
How old is your LCD?
This type of failure is not a DIY for sure because the problem could be on a flex ribbon cable that connects the main digital LCD controller board and from there to the LCD screen.
If your LCD is less then a year old, still can be repair or exchange under manufacturers warranty.
    Genius:
  • 2,035 Answers
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..if this fails then change the cable cord ....
  • Anand Kumar
    Anand Kumar Sep 24, 2008
    You need to try again to install the firmware ,if this fails then you may need to replace memory of the tv which is corrupted during the up gradation .......
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
Is T-con Board in Legend TV MOdel LE3233B THe cause for no picture just vertical Lines Have good sound
Oct 23, 2015 | Televison & Video
How do I fix vertical lines and no picture.
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
How do I fix 4 inch vertical line on my t.v?
Line, faults & possible causes to TV screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 01, 2015 | Sanyo Televison & Video
Laptop screen issues
This is a bad pixel sensor. Your screen has hundreds of vertical and horizontal pixel sensors on the edge, if one goes out on either end it causes a dead pixel line through the screen. Unfortunately, the only way to fix it is to replace the screen. If you can live with the annoyance, I've seen screens last for years with a pixel line without any other problems.
Jul 15, 2008 | Toshiba Satellite P105-S6104 Notebook
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Red line on screen
The vertical line, in my case, was due to a bad contact on the flexible printed circuit. I fixed the problem by using a piece of a rubber eraser to apply downward pressure on the flexible circuit as shown in the picture. To locate the faulty section lightly push on the flexible circuit from lef to right untill the line dissapears. 9f78570.jpg
Nov 08, 2007 | LG DU--50PX10C 50 in. Plasma Television
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Memorex MLT3221 32 in. LCD TV Logo
107 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
