Question about Microwave Ovens
The digital reading on the clock - some of the numbers don't light up and you can't tell what time it is, or the number of minutes it is cooking. Can this be fixed or replaced?? We have a Sharp, model R1502
  • 958 Answers
It can not be fix. it could only be corrected by replacing the display but the display is connected to the whole board. so order the whole pc board.
tnx 4 using fixya,
drcool
Posted on Sep 22, 2008
How do I change temp and time while food is cooking?
all is explained in the user manual
if you have just put food in the even and pressed the start several times to get a number of minutes to cook but want to increase that time just press start again the number of times that you want the cook time to increase
for example :-
you put a frozen pie in the oven and your start operates in 30 second increments and you have pushed it 3 times and it starts cooking-BUT - you read the cooking instructions and it says cook for 4 minutes, just press the start another 3 times while it is cooking
the new cook time will show on the display
Dec 30, 2016 | Microwave Ovens
Kenmore pizza microwave beeps constanly
This is not a solution, it is a clarification request, but it looks like FixYa took away that helpful option, too.
I would suggest you post a whole new help request and be sure to tell us:
1. The FULL model number from the tag in or on the microwave. A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
2. Let us know when it beeps. Is it only after cooking? While it's setting idle?
3. Next, let us know if the display has anything in it besides the normal clock time.
A good first step might be a hard reset, accomplished by unplugging the oven for a minute or two, plugging it back in, then resetting the clock.
Dec 11, 2012 | Kenmore 20" 1.1 cu. ft. Pizza Maker and...
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
May 11, 2011 | Microwave Ovens
I have a GE Profile Spacemaker model JVM1660SB005, maufactured in November 2000. I attempted to change a burned out bulb on the left side. I did not check the manual to see how to remove the bulb, nor...
I regularly see (and repair) this light and / or fan failure on model JVM1660SB005 and most any model of over the range microwave.
The problem is on the controller assembly, which I regularly repair very affordably.
At my Web site, you can get details, plus I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 05, 2017 | GE Microwave Ovens
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
Does not cook - time counts down extremely fast
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Then let us know if the hard reset does not fix it.
and please reply back with your brand and model number so we can help you.
Feb 06, 2009 | Goldstar MV-1526 Microwave Oven
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
You can actually download your owner's manual here
Mar 10, 2008 | Microwave Ovens
Microwave Ovens Logo
71 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
