Question about Onkyo TX-DS989 Receiver
Daigram or set up for my room
The reason as stated by bodiwala:
MAY I GOT DIAGRAM OF SETTING,DISTANCE,DELAYTIME, DESIGN SITTING FOR MY ROOM.? My room size is 16ft.1" X 17ft.3".00. Hight is 10ft. 6" .I have Onkiyo
898 A/V Receiver and thx certified LCR Speaker with 4 diopole surround &
back surround . L- C- R speaker & surround and two back surround are place as attech file herewith Ditance L-C-R 10ft .6 " & SURROUND LEFT & RIGHT ARE 8ft .6" and back left -right Back surround 6FT.6" ARE far from my iistaning -sitting . . I put SPL METTER incenter room and set at 82db in all speakers.i.e left +8 db , center +5 db, Right +8 db, right sur +2 db , back sur. left +4 db, right back sur.+4 ,& left sur +4 db Woffer JAMO D-7set near front Left at 9ft. 5" far my sitting on +3 db in ONKYO 898 AV RECEIVER.I got good sound .But WHAT & WHICH set delay AND
distance in A/V.So what do I do .Please guide to me properly for same and got
3 Suggested Answers
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
  • 17 Answers
SOURCE: Hi We are setting up our
Hi there. If you are running a 5.1 speaker system, make sure your surround speakers are on the surround terminal NOT ON THE SURROUND BACK. the surround back is only for the 7.1 speaker system.
Posted on Nov 28, 2008
I've just set up an echo dot in another room but it's taken control of my sitting room lihgts from my echo plus which now say sorry, i didn't see sitting room lights.
try renaming the room of your lights and make sure both echos are synced up to one account otherwise it may make both of them confused on how to control the lighting in your home
Dec 16, 2017 | Echo Computers & Internet
What does economy button mean? When it is not on economy it goes above the desired temperature setting but when it is on economy it never reaches the desired setting. Can you help??? Do others have th
According to the owners manual, the "Economy" mode is designed to reduce the temperature setting by 2 degrees every hour. May not be what you were expecting... On the too hot issue: Check the thermostat setting - it can read either Celsius or Farenheit - Make sure you are setting it to what you think you are... Recommendation: if it is heating higher than set temperature is 1) set the temp lower and see how it does or 2) call a repair man to check and calibrate the thermostat.
Jan 15, 2015 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
There are several 'types' of electric air heaters. Some have solid-state control boards, others, bi-metalic strip, and open contacts. The most simple is a bi-metalic strip and an adjustment knob for the temperature. Turn knob to lowest setting, plug unit in, turn knob to full, then when room is comfortable, then adjust knob until you hear a click. now system will cycle on - off keeping the room at the temperature you set.
Apr 16, 2014 | Heating & Cooling
What is the best speaker volume settings for 5.1 system my receiver is Yamaha rx-v430 and room size is 15x20
As this receiver does not have automatic speaker calibration, you need to set the volumes manually. The best is if the left and right speakers are at the same distance from you (then their volumes can be equal). If one speaker is at more distance than the other, the volume must be higher for this speaker.
You can find instruction for volume setting at p. 21 of your receiver manual. There you can also find settings of the speaker mode - that depends on the specific speakers you have. You can define for each of 5 speakers if they are Large/Small/None (on this setting depends where will be the lowest bass tones directed).
Oct 20, 2013 | Yamaha RX-V430 Receiver
Why does my dehumidifier run al the time ,i have the humidity set at 45 and when the room temperaturegoes down to 55 it keeps running.
The 45% setting is too low and the setting is never satisfied, so the unit keeps running to try and reach 45%. Try setting to 50 or 55, this is a very comfortable range. I was not clear on the room temperature being at 55 degrees. Is this what your thermostat is set to or is this the actual room temperature. Brrrrrrrrrrrr
Sep 01, 2011 | Fedders A7DH45B2A Dehumidifier
What is the best locxation for 901 series v1
Optimal placement of these like speakers of any design will vary depending on room dimensions and your listening distance from them.
A good place to start with them would be the same distance apart from each speaker as they are from the listening position. In that position they should also be placed closer to a rear wall than any side wall, approximately half that distance.
Dec 10, 2010 | Bose 901 VI Main / Stereo Speaker
I find that even in a reasonably well lit room my camera struggles to pick up a clear image and always appears to be a lot darker than in real life. I would assume that on automatic setting this shouldn't...
Try bigger ISO-setting (in a well lit room 400-600 and darker even 1600). Also try to fix the exposure according to the darker parts of the room.
Aug 05, 2010 | Cameras
This question has already been asked, but I am still unsure .I own a flat with a Dimplex night store heater. It has two dials. One is 'Room Temp Boost' and the other is 'Input'. 'Input' is obviously the...
it does not relate to the time of day it relates to the temp in the room
as you know most heaters do not run continuously, they cycle on ambiant temp.
the boost setting is actually tweeaking that cycle,
you are actually setting the vairence in the temp setting
each modle is slightly differant but
here is an example
9 late boost, might let the temp differential drop as low as 25 degrees
1 early boost might only allow a 2 degree differential
Oct 27, 2009 | Dimplex DS5603 Heater
What do the controls on a portabel AC mean. Like the mode button.
my 4m40mitsubishi model have something nocking during a litlle accelerating in the acelerator
Oct 07, 2009 | Heating & Cooling
WHAT speaker distace & delay .sitting and Db in my AVR AS MY ROOM SIZE
Hello, if you have the speaker set up microphone I suggest that you use it to calibrate the speakers and it will set the distance and delay. Thank you, Onkyo USA
Mar 02, 2017 | Onkyo TX-SR605 Receiver
Onkyo TX-DS989 Receiver Logo
49 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
