Question about Hoover Nextra 160 HNWF 3137 Front Load Washer / Dryer
Hoover washer HNWF 3137-80. Power available, start machine timing light for cycle lights, door light flashes and door locks but door lock light continues to flash. Assume this indicates that controller not getting locked signal and theefore water solenoid does not open and hence machine does not start. Where do I look first please
5 Suggested Answers
SOURCE: Hoover Nextra HNWF 3137
this is a condenser washer dryer so water should evaporate to condenser then empty!
Posted on Feb 05, 2008
SOURCE: Hoover Nextra HNWF 3137 washer/dryer
I have the same problem exactly please send me the solution with confirmation of the exact part requested my machine is HOOVER HNL3137 1300rpm/7kg thanks
Posted on Jun 02, 2008
rylee_smith
  • 8619 Answers
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 18, 2010
ercupa190
  • 12223 Answers
SOURCE: Hoover Nextra HNWF 3135 door will not lock
1) test the switch door, you do not have error code.
see the video, and replace for defective switch, or loose wires or broken, or burn.
God bless you
Posted on Jun 29, 2012
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover Nextra HNWF 3135 Door Not Locking
1) since you do not have any error code, because you do not mentione, we must shure you have problem with the switch door, test for open or defective and replace, Test the wires loose, or broken wires.
God bless you
Jun 28, 2012 | Washing Machines
God bless you
Jun 28, 2012 | Hoover Nextra HNWF 3135 Front Load...
It's STUCK
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer. Please post back for any further assistance.
Daniel
Jul 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Hoover washing machine front loader, has power, have reprogrammed, but still won't start. Door lock light won't come on. For the last few washes before it quit altogether, the time lapse between pressing...
Hi brennanjodi
I think your door interlock needs replacing. Turn off the power undo the front of the door gasket and that will get you to the lock mechanism. They're about £20 to replace.
Adrian
May 14, 2009 | Hoover PE235 Front Load Washer
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hoover Nextra 160 HNWF 3137 Front Load Washer / Dryer Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
