Question about Philips 32PFL7332D 32 in. LCD HDTV
Software Upgrade. I was updating the TV Software and now it is stuck on that screen, no matter what I do I can?t get off that screen even if I unplug it and plug back in the TV comes on by itself to that screen only. Is there anyway to reset it somehow back to original? Or do you have any other solution? I called Philips and they a tech need to service it no help there. Thank you
  • 3 more comments
  • charmouta Nov 07, 2008
    can anyone provid a solution to this problem? please.
    tried that no help if the TV is out of warranty, is there a way to rewrite the memory manualy or any other suggestions?
    does anyone have any other ideas?
    i have done that many time same results.
    any other ideas please for a fix, i have tried hard reset several time and tried redoing the software update several times no luck.
    Scholar:
  • 155 Answers
Taking it to the service center is much advisable.as its the problem internally due to the upgraded software.so dont take any risk call the company servicenter.it will be solved. thanks.
Posted on Nov 07, 2008
    Sergeant:
  • 207 Answers
Charmouta,
In order for me to try to find a solution for you I ned to know What model the Philips tv is. And any other details you feel may be pertinent
Thanks
Dave
  • 10,594 Answers
No other way as software in ROM is damaged and can't be corrected or restored. Please ask Philips Service to replace ROM board.
    Genius:
  • 3,422 Answers
Please do a hard reset by unpluging all the cords of the TV for 4 hours ,even the power cord.
Let me know the result.
  • Philips Master
  • 19,396 Answers
There is no reset.
If the software upgrade procedure is interrupted, the TV can get irreparably damaged.
Ring immediately the manufacturer using the phone number listed on the user manual.
    Sergeant:
    Novelist:
  • 196 Answers
Hold the setup or menu key on the remote, then at the same time hold in the setup or menu button on the TV. Wait for 10 seconds and the engineers menu will display. Select Factory reset and power down your TV
try it .
I have a Techwood TV that started running a software upgrade ages ago but the upgrade got stuck so far through. Now, when I turn on the TV I get the 'updating software bar' across the middle of the s
Upgrade process have been interrupted by any way. Try a reset to this TV, and check. If it do not help you, contact any service technician. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 19, 2014 | Televison & Video
Screen stuck on "please wait"
Software corruption problem. You have to upgrade it with latest firmware. Ask Dynex about the latest software. If you wish to get more details, check this link. http://electrohelponline.blogspot.com/ Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. More than Nine and half Lakh viewers cannot be wrong.
May 16, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Tv stuck screensaver
TV stuck on Screen saver even after turning off power to the TV and then back on? If so Software problem is what I suspect especially if SMART TV. Firmware update may have to be done "if" smart tv", system might be corrupted, please advise, cheers
May 02, 2013 | Computers & Internet
50HPX95. Need Firmware\r\nHad a failed video board (PD2222C). I purchased and replaced this board with same revision, but tv thinks it is a 42" versus 50". Does anyone have the firmware to...
Notice (Read Prior to Beginning the Software Upgrade)
The following events may interrupt the upgrade process and result in an inoperative unit.
1) DO NOT unplug the Power Cord during the software update procedure
2) Avoid loss or interruption of power during the software update procedure
3) DO NOT Press the power button on the unit during the software update procedure
In the event of software upgrade failure please contact TOSHIBA Customer Service at 1-800-631-3811
Feb 11, 2011 | Toshiba 50HPX95 50 in. Plasma HDTV
Bush hd freesat topbox will not switch off or operate. plugged in hdmi cable to box and television, switched on box started software update, after a while screen went blank since then nothing on screen and...
blobby 1589, my Bush freesat box has just done the same. Power going to it. Blue light on. Cannnot turn the box on. Screen froze before it turned off. Tried unplugging it. There was a software upgrade 2 days ago - wonder if that has anything to do with it
Mar 06, 2010 | Audio Players & Recorders
When I turn on myDell 32" LCD TV I get a screen that says "Software upgrade Application RO.9_D06", "You are about to upgrade your TV. If you do not want this, turn off your mains power." But I can't turn...
To get rid of the screen. Unplug It.
The TV is locked in a state of only being able to perform the update.
So if this is possible why not just do it. (push the main button on the screen) Wherever it may be.
Nick
Oct 15, 2009 | Dell Televison & Video
Screen stock on Software Upgrade Application
First of all the software update may not have been done yet, when tv's go through an update (depending on which update) the set can turn it's self off and seem to be done, but you need to wait it out and the set will turn it's self back on, Wait it out for about 30 minutes before doing anything. be paitent. UNPLUGGING THE SET CAN DAMMAGE THE TV DURRING A SOFTWARE UPGRADE!!!
If after a LONG period of time try unplugging the set and re-setting the micro. But only as a last resort!
If the upgrad failed and you can't get the set to function properly you need to change the ssb board. If the set is in waranty, waranty should cover this.
Sep 03, 2009 | Philips 42PFL5332D 42 in. LCD Television
Philips 32PFL7332D 32 in. LCD HDTV Logo
346 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
