Kyocera Copystar CS-1820 Black and White Copier
Problem for Kyocera Copystar CS-1820 Black and White Copier
KYOCERA copystar CS-1820 ERROR C6000
By NHPA on Sep 22, 2008
Hi I have an error message that says... error occurred call service person c6000 on my KYOCERA copystar CS-1820. I dont know how it got there and it will not go away. It will not even turn off using the power button. The only way to power it down is by un plugging it. Please Help!!!
Same Problem
Oct 07, 2009
-   how can i solve this problem-   nendashaw
Solution #1
posted on Sep 24, 2008
Somewhat Helpful)
KyoDoc
Rank: Wiz
Rating: 93%, 48 votes
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Was this helpful?
Yes
No
Popular Solutions for Kyocera Copystar CS-1820 Black
Questions and Unsolved Problems for Kyocera Copystar CS-1820 Black
Do you recommend Kyocera Copystar CS-1820 Black and White Copier?
Answer
Answer
How do you set the fax mode to manual reception? Copystar cs-1820
Answer
The scan to file is terrible, I have a share on each workstation "\scanner" and each user... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kyocera Copystar CS-1820 Black...:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
