Question about Reddy Heater-30,000 BTU Propane Forced-Air Heater
Dyna Glo forced air propane heater
When I plug the heater in, the fan starts, and the igniter is firing...when I move the dial to the "low/ignite" setting and keep it depressed, it fires up; when I release the dial, the igniter is still clicking. When I move the dial to med or high, the igniter still sparks. Is this supposed to happen?
I just received this from a friend and there is no manual. I'm not sure if the spark keeps it lit, or if it should shut off once I release the dial. There is s tube inside that glows red, so I figured that is what generates the flame.
  • bkboyes Dec 13, 2008
    THANKS greatwater....I have used it a couple of times here in CXhicago, and it works just as you stated. At least I know it is normal.
...found out that this is a continuous ignition heater so the igniter is always on.
Posted on Sep 23, 2008
It is a continuous ignition. I have been using one seasonally for 5 years.
Clicking the whole time.
It does no harm for the spark ignition to run. The bright red tube is the thermocouple. A simple temperature saftey switch.
It tells the control board that there is a fire and it is safe to allow gas into the burner.
No fire, no red tube. No gas to burner and vice versa.
Posted on Dec 13, 2008
2 Suggested Answers
  • 80 Answers
SOURCE: I have a dyna glo unvented gas fired room heater
try the maintenance procedures on page 17. (click to see)
Posted on Oct 08, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
Jan 12, 2016 | Heating & Cooling
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
Dyna glo pro forced air heater won't ignite?
I've had mine for about 8 years now. Just started spitting out fuel and failing to ignite. Took it all apart and found a couple of cracked lines where they went on to the fittings. One was to the air pump and the other was a fuel line at the manifold. Cut them both back and reattached, but it still wouldn't ignite. Then I checked the pressure coming off the air pump and it was at 2 psi, should be at 3.4 on mine. Adjusted the fuel pressure up and bingo, it lit right up as soon as the pressure was right.
Jan 02, 2012 | Dyna-Glo Heating & Cooling
Dyna glo pro model #rmc kfa 125tdgp flashing code e1
I have same heater and problem-1) Check fuel inlet screens at bottom of hose in tank 2) Check air filters at fan module opposite end of the fan blade 3)Check for spark in ignition chamber 4) Check for fuel flow in ignition chamber (look at pressure gauge at opposite end from air exit) You'll have to remove the top cover to do these checks. The side covers will hang on each side ok. I hope these checks help you out.Good luck.
Jan 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
My Dyna glo Heater RMC-KFA210WH-03 will not fully ignite
I just bought one. The fuel line was cracked. Replaced it 2$ fix
Jan 27, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
My Dyna Glo heater forced air heater worked great last year. I run it on Diesel and ran it empty before putting it away for the summer. Went to fire it up and it wouldn't work. Replaced all of the cracked...
the filter in the tank line is partially clogged with gel from useing diesel fuel you should really use a anti gel agent when running a sulphur type fuel in a unit designed for white gas/ keosene
Jan 20, 2010 | Kitchen Ranges
Century Dyna-Glo Propane Construction Heater, fan stays on?
The heater is designed to continueously run the igniter , so as if there is a flame-out ,it will reignite the burner,and not dispurse unburned gas into your enviroment.
Jan 11, 2009 | Century Tool 2320I Heater
Reddy Heater-30,000 BTU Propane Forced-Air Heater Logo
1,126 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
