Spinning out of control!
My washing machine sounds like it is going to come through the wall. It only does this on the spin cycle. I have taken the cabinet off and made a few observations, but I can't determine what the problem is. I have noticed that one of the base pads has deteriorated. It is the back one. The 2 up front seem to be ok and the plate pads seem ok. I also have changed for level and that seems fine so. Pleae help!!!
  • Anonymous Sep 22, 2008
    Mine has the noisy spinning since the third or fourth month we own it!! We finally have the company come out (still under warranty). The techician told us that it sounds like we have used it 6-7 a days for the last 7 years. We are just a family of four. The problem seems to be the bearing. At any rate, he is coming back with parts to fix it this week. We also have the F35 problem. I am not impress with whirlpool anymore.
I could not find anything wrong expect for a snubber pad. I went ahead and started over from the beginning with releveling everything. That seemed to fix the issue. I am however going to go ahead and replace the snubber pads.
Posted on Sep 23, 2008
I have whirlpool lsq9110pw2 washing machine. During the spin cycle, there is a clicking sound, and eventually you can smell and see smoke. I have replaced the motor couplings and it still does the same...
When it is spinning open the lid and see if the spinning stops or if it is relational to the spinning of the drum. It sounds like either the clutch is bad or the brake shoes are rubbing or maybe something is stuck between the drum and the tank wall.
Oct 17, 2014 | Washing Machines
Washing machine washes rinses and spins but not automatically
sounds as if your timer has gone out of the unit. The timer controls the cycles.
Jan 28, 2012 | Whirlpool Washing Machines
The washer will not go in med spin or hi spin and the clothes are coming out wet? It just rotates slowly forward and reverse when the control is in spin cycle???
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Frigidaire FTF530FS Front Load Washer
My washer will not empty all of the water out on the spin cycle, it does not matter which wash cycle I have put it on. I have even tried the Drain and Spin cycle. I have even taken all of the clothes out...
heatman101
Apr 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer does not spin out during the spin cycle. Everything else is working properly.
heatman101
Apr 14, 2011 | Washing Machines
Neff washing machine not spinning
sounds like motor brushes have worn out will need to remove motor to replace they are inexpensive.the clicking is the relay telling motor to rotate clockwise or anticlockwise.
May 30, 2009 | Neff W4380X1 Front Load Washer
Washer Problem
Could be the motor controller failed - a loose belt, or a lid switch.
Further testing is necessary without guessing.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
Washing Machine Stopped Working
Hi Beth, sounds like you broke a belt. You can verify this by pulling the washer away from the wall and tipping it back to look underneith. Should have two belts, pump and drive. The part numbers are 211124 pump and 211125 drive. Catriver, post back.
Aug 02, 2006 | Maytag Dependable Care LAT9706
Washing Machines Logo
144 people viewed this question
Top Washing Machines Experts
