Question about HP Office Equipment & Supplies
My printer, HP photosmart C5180 ALL in One stop printing. Ink sistem fail. The screen shows error Oxc 18a0101 I replace all catrige and still not printing.
SOURCE: Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Posted on Feb 20, 2008
  • 133 Answers
SOURCE: Black ink not working on HP C5180 Photosmart
Try a hard restart, which simply means unplugging the power cord of the printer, and replugging it after one minute has passed. If that does not work, then rerun the CD used to install the printer. Both techniques reprogram the electronics, to a certain extent.
You can also visit the HP website, to see what solutions are being offered for various printer problems. They probably have a number to call, in case you need to talk to a technician.
Hope these suggestions help you out.
Posted on Jul 04, 2008
SOURCE: HP Photosmart C5180 Ink System has Failed Error:0xc18a0306
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
Posted on Nov 29, 2008
SOURCE: oxc18a0201 ink system failure. Apparently
1.-press key * # 2.-enter code 123 and select a Hardware faliure status 3.- Press clear OK and finish cancel for end restart print
Posted on May 28, 2009
  • 154 Answers
SOURCE: HP photosmart C5180 all in one: Ink system has failed
Here's a link to a procedure that one individual used to fix the same problem with his printer. I can't guarantee this will work in your particular case.
HP C5180 All-In-One Printer HARD RESET:
  1. Hold down HELP + OK button and unplug printer (could experiment with regular power-off, but I opted for brute force)
  2. Hold down HELP + OK button again as you plug the printer back in. Then power it on, if it doesn’t power on automatically. Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
  3. Now you can release the buttons and simply power it back on. (I held my breath, but that’s not required.)
    • I got an error message about “improper shut down” since I unplugged it w/out powering down. After I clicked “OK” the printer was just fine and didn’t mind anymore. And now I can print.
reference: http://www.mlnarik.com/jewel/2009/05/21/how-i-fixed-my-hp-c5180-printer/
Posted on Aug 07, 2009
Error Oxc 18a00001
you may need another print head with that error code message. I would contact HP Total Care (1800-474-6836) and check to see if your printer or print head is in warranty, and it could be replaced.
Error 0xc18a0001
Jan 20, 2016 | HP Photosmart D7260 Printer
How do i fix ink system has failed error code on my hp photosmart c5180 printer?
try master rest for hp C 5180
Master Reset:
Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. . This sorted it.
Jul 26, 2014 | HP Photosmart C5180 All-In-One InkJet...
Will not print. Displays "Error Oxc 19a0035
Kinldy remove printer, uninstall and then reinstall the prrinter software, then connect the printer and test.
If there is mating of the printer and shows a errror, Just check on the rollers, the ink head drive section for any paper or restriction to the movement of the mechanism.
If there is not result, the main board can be faulty.
Sep 05, 2010 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart C5180 all in one is displaying this error Ink system has failed refer to printer documentation OXC 19a 0035 cannot find out what it means?
The "Ink System Failure" is caused by air in the ink feed tubes. This problem can happen if you allow your ink to run all the way out or if you use poorly refilled ink cartridges that have air bubbles in them. To clear the error you will need to perform a purge on the printer. We have a step by step guide to this procedure posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ This should get you back printing in about 10 minutes.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 19, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink system has failed. Unable to print. Refer to printer documentation Error: 0xc18a0201
I have a HP photosmart C5180 all in one. It has an error message that says....Ink system failed unable to print refer to printer documentation error OXCa0501. By chance would you know what to do to fix it? Thanks
May 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have an Hp c5180 and I am unable to print.
Look here: http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp
Oct 04, 2009 | HP Photosmart C5180 All-In-One InkJet...
On HP Photosmart C5180 Error Message 0xc18a0201
call hp total care 1800 4746836
u knw i cn tell u the steps but if u do even 1 of the steps wrong ,ur printer wont work anymre so contact them
...hp technicians will be able to take care of u
thanhks
Aug 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error # Oxc18a0301
Shut down your printer by pressing Simultaneously Cancel + OK + Black + Color.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 27, 2008 | HP Photosmart C5180 All-In-One InkJet...
35 people viewed this question
Ben Johnson
