Question about HP Office Equipment & Supplies
My computer will not recognize the printer. I canceled a printing job and since then the problem was created. I tried to delete and it says deleting, but it seems everything is locked up and will not recognize anything in regard to the printer. I have unplugged the printer, use the on switch and did all of that, but to no avail. Please help!
Completely delete your printer by opening up your control panel and click on "DELETE HARDWARE" and choose the printer that you want to delete.
After you delete your printer, if you have an install disc, then try to reinstall it.
If you do not have an install disc, then go to the Web site of the brand name of your printer.
Unless your printer is very old (10 years or older) the Printer site will let you download a program that will install your printer for you.
Posted on Sep 22, 2008
I have try to delete a printing job and it will not print and will not allow anything to be print. However, I was able to delete the other jobs after the first job but the first job willnot delete
Sometimes if the printer cable is unplugged it will reset. Try that. Also the printer menu should include cancel print jobs. Is that cleared? I would also turn off computer for a moment, and turn back on. Thqat may clear the print job.....
Apr 19, 2014 | HP Photosmart C4100
I have a lexmark x3400 printer and a windows 7 operating system. The current print job won't cancel and won't delete and I can't print anything else. I can't uninstall the device as it says the printer...
You will need to clear the print queue first before trying to send another print job. - Browse to Start -> cmd... and type in "NET STOP SPOOLER (this will stop the print spooler service) - Browse to your windows\system32\spool\PRINTERS\ folder - You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files. - Browse to Start -> type cmd... and type in "NET START SPOOLER" (this will restart the print spooler service) - Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Apr 24, 2011 | Lexmark X3470 All-In-One InkJet Printer
Cant delete printing job
try Ctrl Alt Delete to end it from the task manager. Then restart your computer.
Aug 01, 2010 | HP Officejet 5610 All-In-One InkJet...
My printer has a job waiting that I can't cancel. I've tried everything including turning off the printer to erase the memory, and completely restarting my computer. Nothing will delete this print job
your job is stuck in the printer que, to cancel this go to control panel, open printer and other, right click on the printer icon, delete the job in que (are you sure you want to delete, yes)..........and you are done
May 10, 2009 | Office Equipment & Supplies
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
New z2400 will not print a page (worked fine for the last couple of days), pop ups state in process of printing 2 pages, printer is diconnected and power off, but unable to delete printing process on the...
This may help you
How to force delete print jobs Fortunately, there is a way to delete the hung print job without having to save all your work, close all your applications, and restart your computer. Here's how (note that this is intended for Windows XP systems, but a similar approach works on other systems - if this doesn't work for you reply below with your Operating System and version):
  • Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
  • Browse to your windows\system32\spool\PRINTERS\ folder
  • You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  • Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
  • Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Voila :) You should see that annoying hung print job finally disappear completely and you should now be able to resume printing without having to restart your computer.
From http://community.contractwebdevelopment.com/how-delete-or-cancel-hung-print-jobs-windows
Dec 12, 2008 | Lexmark Office Equipment & Supplies
Can't cancel documents in the queue
Hi grt2b1915
go to printer not document selct cancel all while the printer power off.
thanks
Hamedo
Nov 22, 2008 | Office Equipment & Supplies
Not printing and nothing is paused or on the print list.
First of all you must let canceled print jobs finish deleting before sending new jobs, if the job is taking too long try restarting the computer with the printer on to clear the jobs this usually works if not then after restart open the printers folder and cancel all jobs here. let them finish deleting while the printer is still on (they must remain in communication during deleting jobs. Once all jobs are gone, remove the power brick from the printer for about a minute then reinsert and let the printer start up if it doesn't after a minute or so just turn it on once it finishes then try printing again.
Oct 14, 2008 | Dell 926 All-In-One InkJet Printer
Printing status frozen and won't delete or print
Have you tried unpluging your printer from the computer as well as unpluging the printer from the electrical? If that doesn't work you should start from scratch... that is remove the printer from the computer memory, delete it, turn off the computer, turn on the computer and go through the installation process as if you just purchased the printer. Barring any mechanical problems as in jams or the such, the printer should return to operational status.
Oct 07, 2008 | HP DeskJet 5150 InkJet Printer
Will not print
Try unplugging the USB cable from the back of the computer, not from the back off the printer. Also, try deleting the printer from/at the printer/fax page and restarting your computer so it will reinstall. In either case, when checking the printer/fax folder, make sure there is nothing pending printing. If there is, click on delete all pending printing jobs. If there is a print job pending and you can not cancell/delete this job, then you must delete the printer icon and restart your computer. Aloha!
Sep 20, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Ben Johnson
