Configuration of DNS with LINUX
Hello all,
I am going to configure an ISP so want to configure the DNS and DHCP Server on one machine so how i can configure
  • 61 Answers
Which version of linux u plannedto install?
Posted on Oct 23, 2008
My server has 2 NIC one of them connected to the router (ISP) and one of them is connected to the LAN.But DHCP and DNS working but there is no internet to the Host and also the server itself.when i...
This is more a configuration error. Depending on how you have your DHCP setup, you may need to adjust it's setting. No mention of what os you are using but if you set your DHCP to give IP addresses only to the LAN, set the ISP NIC address to receive its ip from the ISP provider, you should be able to get Internet access to your server and the LAN.
If you have done so, use the server os to setup your Internet connection. Answer a few questions about how you connect to the Net and the os will do most of the configuration for you.
Good Luck
C2Solutions
Jan 24, 2011 | Dell PowerEdge 1800 Server
Tip
DHCP Server configuration in Linux
Linux is a UNIX based operating system. It is a server operating system. REDHAT Linux is Enterprise version of Linux. Now a day's Most of corporate sectors use red hat Linux as server in their company because it is secure very much.
Full form of DHCP "Dynamic Host Configuration Protocol. DHCP server assigns IP addresses and other network configuration information like subnet mask, broadcast address, etc to computers on a network. The DHCP assignments are the following.
Lease Request: Client broadcasts their request to DHCP server with a source address of 0.0.0.0 and a destination address of 255.255.255.255.
IP lease offer: DHCP server replies with an IP address, subnet mask, network gateway, name of the domain, name servers, duration of the lease and the IP address of the DHCP server.
Lease Selection: Client receives offer and broadcasts to al DHCP servers that will accept given offer so that other DHCP server need not make an offer.
The DHCP server then sends an ack to the client. The client is configured to use TCP/IP. Lease Renewal: When half of the lease time has expired, the client will issue a new request to the DHCP server.
Installation of DHCP server: First of all while install the RedHat Linux enterprise version server be careful about the ports and the services must be turned on. To create DHCP server in Linux first download DHCP RPM package and install with "rpm-ivh" command. Where I have done it there I have create YUM server, so easily I have download and install it by YUM (yum install dhcp version). DHCP package will locate in /usr/share/doc/at Linux file system. I copied the DHCP's files from /usr/share/doc/ to /etc/dhcpd.conf.. Then I started to configure the dhcpd.conf file to route the DHCP server in there local network. I have open the configuration file with "vi" command. Then commented out the lines from "default gateway to option netbios" because system don't read the commented lines. After that I set the range of IP address in dynamic- bootp of their local assumption of system. I have change the "next-server" with the dhcp server name and have also change the fixed address with the dhcp server IP address (end range of dynamic IP). It is very easy job to configure DHCP server. After configure the .conf file of dhcp just turn on the service with "chkconfig" command and restart the dhcp service. After that entire job I reboot the system. And after rebooting of server I turned on the other client system. While startup the client system without static IP address all of those picked up IP from dhcp server and going on successfully. I have prefer the command line mode to do the total job.
The DHCP server configure file is following:
ddns-update-style interim
ignore client-updates
subnet 192.168.1.0 netmask 255.255.255.0 {
# The range of IP addresses the server
# will issue to DHCP enabled PC clients
# booting up on the network
range 192.168.1.201 192.168.1.220;
# Set the amount of time in seconds that
# a client may keep the IP address
default-lease-time 86400;
max-lease-time 86400;
# Set the default gateway to be used by
# the PC clients
option routers 192.168.1.1;
# Don't forward DHCP requests from this
# NIC interface to any other NIC
# interfaces
option ip-forwarding off;
# Set the broadcast address and subnet mask
# to be used by the DHCP clients
option broadcast-address 192.168.1.255;
option subnet-mask 255.255.255.0;
# Set the NTP server to be used by the
# DHCP clients
option ntp-servers 192.168.1.100;
# Set the DNS server to be used by the
# DHCP clients
option domain-name-servers 192.168.1.100;
# If you specify a WINS server for your Windows clients,
# you need to include the following option in the dhcpd.conf file:
option netbios-name-servers 192.168.1.100;
# You can also assign specific IP addresses based on the clients'
# ethernet MAC address as follows (Host's name is "laser-printer":
host laser-printer {
hardware ethernet 08:00:2b:4c:59:23;
fixed-address 192.168.1.222;
# List an unused interface here
subnet 192.168.2.0 netmask 255.255.255.0 {
on Mar 17, 2011 | Computers & Internet
I can't find the settings to enable a public IP for my dns server. Where are they or is there another way?
Telephone your ISP -- they can provide this information.
However, most ISPs use 'DHCP' ("Dynamic Host Configuration Protocol") which automatically provides IP-addresses of DNS-servers to any device (your computer, or your router) connected to the cable-modem.
Jun 12, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Connection to winows media failed
1. check your netwok calble properly
2. check your router internet connection
3. follow these steps
Accessing network settings loadTOCNode(2, 'moreinformation'); To access the Network Settings area, follow the steps for the version of the Xbox 360 Dashboard that you are using.
New Xbox Experience Dashboard:
  1. From the Xbox 360 Dashboard, select System Settings in the My Xbox area.
  2. Select Network Settings.
  3. Select Configure Network.
Legacy Xbox 360 Dashboard:
  1. From the Xbox 360 Dashboard, move to the System blade.
  3. Select Edit Settings.
IP settings, IP address, subnet mask, and gateway loadTOCNode(2, 'moreinformation'); Collapse this imageExpand this imagenetworksettings-basic.jpg
After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the IP Settings block, you are prompted to select an Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your IP settings from your network or from your modem or Internet service provider (ISP). This option is recommended for most users.
You may have to or prefer to manually configure the IP settings, especially when a static IP address is used. This is necessary only if your ISP has issued a static IP address, or if you have configured the router to issue static IPs (and DHCP is not used). To manually configure the settings, select Manual, and then enter the IP Address, Subnet Mask, and Gateway by using the keyboard on the screen. When the information is complete, select Done.
DNS settings, primary and secondary DNS servers loadTOCNode(2, 'moreinformation'); After you select either Configure Network or Edit Settings, you will be on the Basic Settings tab, which contains your IP and DNS settings. When you select the DNS Settings block, you are prompted to select Automatic or Manual configuration. If you select Automatic, the Xbox 360 console will try to automatically determine your DNS settings from your network or from your modem or ISP. This option is recommended for most users.
You may have to or prefer to manually configure the DNS settings, especially in scenarios in which a static IP address is used or where DHCP is not available or not offered by the ISP. To manually configure the settings, select Manual, and then enter the primary and secondary DNS server names by using the keyboard on the screen. When the information is complete, select Done. Note You do not have to enter a secondary DNS server to connect to Xbox LIVE. A secondary DNS server is required only if the primary DNS server has technical problems.
Wireless settings loadTOCNode(2, 'moreinformation'); To configure your Xbox 360 console to connect to your wireless network by using an Xbox 360 Wireless Adapter, follow these steps:
  1. Access Network Settings .
  2. On the Basic Settings tab, select Wireless Settings.
    Note If the wireless settings area does not appear or is unavailable, click the following article number to view the article in the Microsoft Knowledge Base: 909333 (http://support.microsoft.com/kb/909333/ ) While attempting to view the settings for a wireless network connection, all the wireless functions appear to be disabled in the Xbox Dashboard
  3. Follow the instructions to select your wireless network, select your wireless network name, and then enter your wireless security information.
  4. Select Done.
PPPoE settings loadTOCNode(2, 'moreinformation'); If your Internet service provider uses PPPoE authentication, you have to enter the settings in the Xbox Dashboard if you have a direct connection through a modem. If you use a router or a gateway instead, leave the PPPoE settings blank because the router performs PPPoE authentication. Note If your ISP does not use PPPoE authentication, make sure that these settings are blank. To learn whether your ISP uses PPPoE authentication and to learn the correct PPPoE information, contact your ISP.To configure the PPPoE settings on your Xbox 360 console, follow the steps for the version of the Xbox Dashboard that you are using.
New Xbox Experience (NXE) Dashboard:
  1. Move to the System area of the Xbox Dashboard by using one of these methods:
    • Press the Xbox Guide button on your controller to open the Xbox Guide, scroll to the right to access Settings, and then select System Settings from the list of options.
    • Select the My Xbox channel, and then scroll to the right to select System Settings.
  4. On the Additional Settings tab, select PPPoE Settings.
  5. Use the keyboard on the screen to enter the PPPoE information that was provided by your ISP.
  6. Select Done.
  7. Select Back to return to the main Network Settings area.
  8. Select Test Xbox LIVE Connection to restart the test with the new PPPoE settings that you have configured.
sure it will work thank you
Mar 14, 2010 | Microsoft Xbox 360 Console
I have win2003 i want it serover what can i do
You can do a lot with this operating system.
Some of his features are: DOMAIN Controller, Active Directory, Ftp Server, DHCP, Web Server, Terminal Server, File server etc.
Here i have some very useful links.
About Windows 2003 Server Editions: http://en.wikipedia.org/wiki/Windows_Server_2003
Futures: http://www.microsoft.com/WindowsServer2003/evaluation/features/default.mspx
Configuring DNS Server: http://www.petri.co.il/install_and_configure_windows_2003_dns_server.htm
Configuring DHCP Server: http://www.windowsreference.com/windows-server-2003/install-and-configure-dhcp-server-in-win-server-2003-step-by-step-guide/
Configuring File Server: http://www.windowsnetworking.com/articles_tutorials/File_Server_Windows_2003.html
Configure Printing Server: http://www.brightrev.com/how-to/enterprise/55-best-practices-for-setting-up-a-windows-print-server.html
Configure FTP Server: http://support.microsoft.com/kb/323384
Configure Active Directory: http://helpdeskgeek.com/how-to/windows-2003-active-directory-setupdcpromo/
Configure Web Server: http://support.microsoft.com/kb/324742
All these are only some of his features.
I hope is useful to you and your friends
Mar 13, 2010 | Microsoft Windows Server 2003 Enterprise...
How do i set up xbox live
  4. Select Done.
  6. Select Done.
Feb 11, 2010 | Microsoft Xbox 360 Elite Console - Black
Make additional DNS
Yes, all Windows Servers have the option to install DNS.
Set up a second Windows server and configure it to be a secondary server for your DNS domains on you current server.
Add the second DNS server's IP address to the secondary DNS field to your DHCP scope options and to all computers with static IP configuration so they will use it when your primary DNS is unavailable.
Don't underestimate Window's built-in Help and Support. It will help you install DNS and configure it.
Good luck.
Jul 29, 2009 | Dell Computers & Internet
DNS Name resolution Between private & Public network.
You do not need to configure ISP's PTR records. Instead define their DNS addresses as forwarders in the properties of DNS server under forwarders tab and flush DNS cache.
Mar 24, 2009 | Microsoft Computers & Internet
Setting WebServer On Linux
Hello,You can try this http://www.goresellers.com/ site's more DNS ,here you can make your self as a reseller and get your expected DNS are very very cheap rate, also you got an internet business opportunity ,visit this site for more details.
Oct 18, 2008 | Computers & Internet
Dns error 80710102
Hey peterk18,
First of all, how is your network configured? Are you behind a router? What's it's IP adress, does it act as a DHCP server?
If so try to set up a new network connection and put everything to automatic.. When the routers acts as a DHCP server it will give the PlayStation 3 an IP adress. DNS however is something else. DNS is a system that allows you to browse by a website or hosts name. For example: it allows you to type www.google.com in your browser instead of it's IP.
DNS is essential for Internet. Your router should be your DNS server and your router itself also needs to know a DNS server, this would be the server from your ISP. All these settings are automatically configured via DHCP.
Greetings,
DarkNeogen
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
David Payne
David Payne
