I have a dell computer that no longer will charge the battery. How do I determine if the problem is a bad battery or faulty charging system?
    Scholar:
  • 152 Answers
You can eliminate the possibility of a faulty charging system by testing the output of your charger that connects with the laptop. You can do this by attaching one end of a bulb (rating approximates the voltage output of the charger) to one end of the charger (+ or -) and the other to the opposite end. Using a thin wire will do the trick. If it lights, then your charger is working. If it doesn't, your battery could be the likely problem.
Posted on Sep 22, 2008
Battery not charging dell inspiron 630m
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new dell inspiron 630m battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
Apr 05, 2013 | Dell Inspiron 6400 Notebook
Dell d810 battery not charging
Instructions
Determine if the Dell Latitude D810 battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
5
Apr 02, 2013 | Computers & Internet
Dell vostro 3500 shows battery connected but not charging and intermittently shoes no battery detected
Instructions
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
5
http://www.aurabuy.com/cheap-9-cell-battery-for-dell-vostro-3400-3500-3700-7fj92-04d3c-paypal.html
Mar 28, 2013 | Dell Vostro 3500 Laptop Computer (Intel...
Plugged in not charging
meyers975,
The battery may need to be replaced if it is no longer charging.
NOTE:
The Battery on the Inspiron 1545 does not have the charge indicator LEDs. USE the F3 key or the method illustrated below to launch the Dell Battery Meter. The system bios can also be used to determine the battery charge level.
Navigate to the control panel and click the Power Options icon.
Click the Dell Battery Meter option on the left
Check the Battery Status for the Primary battery under the Battery Status tab. Click also the battery health tab to see what the status reads.
If you need to purchase another battery for your system you can contact the Dell Spare Parts Depatment at 1-877-717-3355
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 30, 2013 | Dell Inspiron 1545 Notebook
My dell demension E521 is giving me a "alert system battery low" message. Any suggestions?
Check the batteries voltage and check to see if the battery is being supplied charge voltage when the computer is off. If both these are good then your low battery message is in error. No charge voltage would mean faulty charger and low battery voltage would mean faulty battery.
Dec 15, 2012 | Dell Dimension E521 PC Desktop
My dell vostro 3300 laptop battery not charging since i re installed windows 7
Laptop battery problems are quite common among owners of all brands of notebooks. On average, laptop batteries last one to three years. Their exact lifespan depends on several factors, such as how much you use the batteries, the number of charge-discharge cycles and the quality of the batteries. Lithium-ion batteries begin to lose the ability to hold a charge over time. Before you replace a laptop battery, consider that there may be other reasons that the laptop is not working properly. You may be able to recharge the battery instead.
1.Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
2. Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
3. Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
4. Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5. Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.I hope you find it very helpful. Best regards.
Dec 09, 2012 | Dell Vostro 3300 Notebook
Dell Inspiron E1505 won't recognize new battery
It won't charge or work correctly if it's not the correct one and of the right voltage etc.I don't know how the battery even went in if it's not the Dell specified battery.If it went in and looked to fit maybe the battery itself is bad but its hard to say.
Aug 04, 2009 | Dell Inspiron E1505 Notebook
Battery not charging on my X59SR, although it sais it does. I'ts 0%.
Hello a_imeri,
So the battery does not charge at all or it just shows that it isn't charged? Does the computer work when it is not plugged in? It sounds like it may be time for a new battery.
Jul 07, 2009 | ASUS X59SR-x5 Notebook
New Dell battery, new AC adapter(not Dell). Won't charge battery
Dell uses a proprietary SMBus protocol over the center pin to communicate the type and power capability of the attached adapter. The laptop uses this information to determine if it can charge the battery without browning out the motherboard. If you use a knock-off power supply that doesn't communicate properly (or at all) over SMBus, then the computer will complain and won't charge the battery. Sorry, Dell has us all right where they want us. Find a used actual Dell adapter on eBay for $20 if you can.
Nov 15, 2008 | Dell Inspiron 6000 Notebook
Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
Computers & Internet Logo
David Payne
David Payne
