Question about Garden
Weedeater Clutch Spring Replace
How does one go about replacing the clutch return spring on this lawn mower?
The spring must be attached to the idler pulley and then threaded through the chassis to an obvious anchor point. Is there a special tool for this? It's a fairly stiff spring that could cause some knuckle busting.
Thanks
Counter man at the local mower repair shop said to use a thin rope. Tried it and it works great. Think I over engineered this problem.
Thanks for your help.
Wayne
Posted on Sep 23, 2008
I NEED THE LOCATION TO ATTACH THE PTO CLUTCH SPRING.
need to know what mower exactly
Jul 29, 2015 | Garden
The clutch return spring broke on my lawn tractor model 917.272242 and i cannot see at what points it connects my diagram is not a real .can you help
If you go to searsparts.com and put in your model number they will have a diagram as to how the spring attaches.
Jun 20, 2014 | Craftsman Lawn Mower
Poulan Pro PB195H42LT Product # 960420107-00 Purchased April 2010a Looking for a photo for the drive assembly for this lawn tractor. The break down in the part's manual doesn't show the spring...
Try using a vice grip to attach spring. Look for wear marks where paint is missing from frame to help locate spring position. Hope this helps.
May 21, 2014 | Garden
Clutch cable installation
  • Put your mower in the lowest position and open the hood.
  • 2 Lift up the retainer spring that holds the clutch cable to the adjustment bracket. Pull the cable out of the bracket.
  • 3 Remove the clutch cable spring from the idler bracket. Pry the spring open with a pair of pliers if necessary.
  • 4 Hook a new clutch cable spring over the idler bracket and squeeze it closed.
  • 5 Slip the clutch cable under the retainer spring.
May 04, 2013 | Husqvarna Garden
Need to know where the clutch spring attaches to under the mower
You removed the engine??? You probably just needed to remove the blade. The only spring I can think of would be a tensioner spring for the belt pulley, which is up front if it's a front wheel drive mower.
Nov 09, 2011 | Garden
YTS 3000 clutch return spring noise, sounds like it is rubbing on something when you release the clutch but I can't even find the spring
The spring will be attached to the tensioner pully right on top, there is a threaded bolt with nut holding the spring on, I just had to order the clutch cable because the spring broke, from rubbing on metal when engaging and disengaging the clutch lever.
Jul 30, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Broken manual clutch cable
You can go to www.Searspartsdirect.com and put you units model number in and order the cable yourself. They can ship it right to your house and you can swap the cable yourself with just simple hand tools.
You can see the details on the idler attachment in the parts schematic when you are ordering your new cable.
Good luck and be careful!
Jul 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Spring is broken
There are many springs on a riding mower. Is it the clutch spring, the idler pulley spring, or maybe the blade brake springs. There are also springs on the brakes and even under the set. Please be more specific.
Aug 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Clutch engages to start engine but wont move F or R
could be one of two things - if the clutch pedal just kinda flops and doesn't spring back, the clutch tensioner spring has broken. lift the hood and look at the frame on the front, right side, you'll probably see what's left of the spring hook hanging there - not easy to replace if you've never done it, take it to a shop - OR, an idler on the drive belt pivot has fallen off or broken...easier, but still some work. the small clunk you heard has me leaning toward the spring
Jun 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to replace a clutch cable
i need a picture or explanation, how does the clutch spring attach
Apr 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
349 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
