Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman 1/2 HP door opener bounces back open
My garage door (not always, but often) closes and a second or two later opens again. This may happen a few times in a row. I have to stop it, close it, stop it...
Other times it just closes properly. Any Ideas?
  • Anonymous Oct 05, 2008
    Mine does the same thing ! I tried disconnecting the sensors but it still does the same.
    One sensors green light doesnt work so I assume the sensor is bad.
  • wozzie Oct 07, 2008
    My garage door opener will not open or close all the way. I have to keep pressing the button many times just to get it to move in either direction,it just stops and sometimes goes in the other direction. It also only open 1/4 or 1/2 way never opens all the way.
Inside your housing there is a plastic threaded screw w a metal t. This screw rotates the door will continue to move til this t hits a metal sensor. There are 2 adjustment screws on the side of the housing. One for up and one for down. Try turning the down sensor to the right ( I believe if not check there is a pic next to the screw) a 1/2 turn or so. Keep making small adjustments til the door stops in the proper spot.
Posted on Sep 13, 2009
    Problem Solver:
  • 8 Answers
There should be 2 sensors on the bottom of your door on the inside, 1 on the right side and 1 on the left side.
These sensors serve 1 purpose to send a beam or reflection to each other.
If something is blocking this reflection or is in front of the sensor the door will always come back up.
It is a safety feature so nothing or no one gets hurt when the door is closing!
Posted on Sep 23, 2008
Don't know Mod. No. lost installation manual, approx. 5 yrs. old Need installation manual.
About 496,000 results (0.43 seconds) Search Results
    [PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
    www.liftmaster.com/.../en.../tucmanuals/114a3044.pdf Chamberlain GroupFasten the manual near the garage door after installation. .... This garage door openerhas been designed and tested to offer safe service provided it is installed, ...
    Manuals Download Craftsman Garage Door Opener Model ...
    www.craftsman.com/search=manuals%20download%20crafts...
    CraftsmanCraftsman has the best selection of Garage Door Openers in stock. Get the Garage Door Openers you want from the brands you love today at Craftsman.
    Craftsman 1/2 HP Chain Drive Garage Door Opener - Sears
    www.craftsman.com > ... > Garage Door Openers
    Craftsman1/2 hp Chain Drive Garage Door Opener Opens by Remote, Inside and from Car Enjoy a great end to every day by ... Owners manual - English (Warranty).
    Free Craftsman Garage Door Opener User Manuals ...
Feb 03, 2016 | Building Materials
How do I update software
Feb 03, 2016 | Kenwood DNX-690HD eXcelon DVD Receiver...
Craftsman 3/4 hp Chain opener.....Door opens and closes by itself. No blinking light, looks like everything is clear with sensors. Half opens then closes, then door completely closes and 5 seconds later...
You most likely have a bad wall control or the wiring to it. An easy way to check this is to remove the connection at terminal #1 on the rear of the motor unit. Just remember that your wall control will not work with this wire off. Your remotes will still work though.
Dec 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door will open and close one time, then it will not open unless i unplug the unit for a few seconds. then it will open and close one time then have to unplug again. it's a craftsman 1/2 hp
The motor has a thermal overload switch that may be causing the symptom you describe. It is to protect the motor in case of overheating. Maybe not operating it so much will help with your problem.
Aug 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener (1/2 hp) won't close proper
Check your door sensors. They have probably been bumped. Tweak them until they are pointed at one another and the small light on each one is lit and not blinking.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
CRAFTSMAN GARAGE DOOR OPENER PROBLEM
i have a garage door opener craftman 1/2 hp model 13953985 the light is flashing 10 times . now you have too hold down on the button to raise and lower .
Feb 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
From the manual:
Security+Light Feature: Lights will also turn on when someone walks through the open garage door. With a Premium Control Console, this feature may be turned off as follows: With the opener lights off, press and hold the light button for 10 seconds, until the light goes on and off again. To restore this feature, start with the opener lights on, then press and hold the light button for 10 seconds until the light goes off, then on again.
Sep 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
823 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
