Anyone got an idea where I can buy a P24 cartridge for an SLBD22 turntable
I get no sound from the turntable. I have replaced the stylus but still no joy. I now suspect that the P24 cartridge is U/S
The proper stylus is the best you can afford. However the cartridge itself will only take certain types. To find which simply enter the cartridge make and model number into Google and see what comes up.
Actually most hi-fi buffs say it's the cartridge and stylus combined that gives the best sound, since many cartridges fit only one stylus it's often the cartridge that is the real choice. Most turntables will take a wide range of cartridges, so you pay your money and take your pick.
The stylus could be as flat as a pancake. So will not fit into the grooves. If you unplug the wires to the cartridge and with the unit connected to your amp and that on power, touch with your finger each of the wires one at a time. You should hear a buzz one on the left and one on the right from two of the wires. If you do that shows that sound will get into your amp. If that's okay I would then buy a new stylus and cartridge. It doesn't have to be the same as the one you have. As long as it will fit on to the headshell.
You look at the cartridge, determine its make/model number if visible and web search for that with 'replacement stylus'. There is no way we can tell what is installed on it.
Bad cartridge if you get a buzz from touching the wires to it once they are removed. That shows that the system is working but the output from the cartridge is rubbish!
The correct stylus will depend on which cartridge is fitted to your turntable - these can vary.
Makers name and model number should be printed on the cartridge.
Personally, however, I prefer to replace the whole cartridge not just the stylus for better quality sound.
Yes it can. On the head of the arm if you look carefully where the needle (to give it's correct name -stylus) is. What it fits into is a cartridge. If you can see letters or numbers on it that will be the type. If you put that into Google it should find it. You should find if it is possible to buy the stylus with or without the cartridge. Though it's often cheaper to buy both. The cartridge will either be screwed onto the head or just clipped on someway. You will find four wires attached to the cartridge. These will have to be removed if you have to replace the cartridge. Make a note of how each wire attaches to the cartridge. As long as you can get a cartridge to fit the headshell you can use any magnetic cartridge for the job. All you would need to do with a different cartridge is adjust the weight to apply the correct pressure to the stylus.
If the cartridge doesn't have any number etc on it, put the make/model number of the turntable into Google adding cartridge/stylus.
That turntable, like many others, has an S-shaped tonearm with a removeable headshell. You can use any standard screw-mount cartridge as a replacement. Which one you buy depends on what you want to spend and your intended use. If you're a DJ you'll need a more rugged cartridge than you do for listening at home, for instance.
One company I buy lots of parts from is Parts Express. Here's a link to their styli/cartridges pages. If you have the original cartridge and stylus, you can check if they have the exact replacement. Otherwise you can browse the other choices. You can find many other sources as well, and you may have an audio shop or musician's store in your area who stock cartridges.
