Question about LG Computers & Internet
LG RH278 DVD Recorder parts
Would anyone perhaps know where I can get replacement parts for this recorder besides going to LG itself ?
  • 244 Answers
SOURCE: LG vs Lite On
both are just the same features just to write file from your hard drive. Maybe your point is you want the video from your VHS tapes will transfer to your hard drive. The only way to copy the video from your VHS is you need an external VHS player at the same time it will record the running video to a soft copy.
Please check this maybe this will be helpful
Please rate me solve if you like my solution.
Best regards,
Posted on Nov 02, 2007
SOURCE: Recording problem with LG RH266 Recorder..
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
Posted on Apr 19, 2008
  • 67 Answers
Click HERE
This is the Dell website driver area, under CD/DVD, you will find firmware upgrades and a driver. Look for the one that best fits your drive, download and run the program.
I really hope that this fixes your problem... If you have any more questions please let me know and I will be more than happy to help you further. Good luck!
Posted on May 16, 2008
  • 207 Answers
1.Turn on the PC. When the HP/Compaq logo screen appears, press the F1 key repeatedly until the BIOS Setup screen appears (on some models this key press may different, F2 or Del)
2.Use the Left and Right Arrow keys to select Main.
3.The hardware-identifying name should appear next to Secondary Master, Secondary Slave, or Primary Slave.
If the name for the drive exists, skip to Step 3. Otherwise, continue to the next step.
Step 2: Reseating cables
If a drive name does not appear for each drive and None is listed in the BIOS, use these steps to open the computer case and reseat the drive cables. Work on a hard flat surface over a non-carpeted floor.
1.Turn off the computer, unplug all cords from the PC, and then press the Power button on the front of the PC for five seconds.
2.Remove the side panel.
3.Remove both the IDE ribbon cable and the power cable from the back of the CD drive.
•If the drive name appears in the Primary IDE section or the hard drive name is now missing, the IDE cable is bad or the drive settings are wrong. Replace the IDE cable and connect it according to the drive jumper settings . That is, if the small rectangular connector (the jumper) on the drive is set to MS (Master), connect the master end of the IDE cable into the back of the drive. If the jumper is set to SL (Slave), use the slave connector on the cable. If the drive is set to CS (Cable Select), you can connect using either connector on the cable.
Step 3: Removing Drive in Device Manager
Remove the drive name from Device Manager:
4.Close the Properties window and select the CD drive name.
5.Click the Uninstall or Remove button (in Windows XP this is the square button with a red X).
6.Click Yes or OK to remove the CD listing. Do not restart the PC.
7.Close Device Manager.
8.If your PC has Windows XP, perform the next step to clear the registry filters without restarting the PC.
Clearing the registry filters in XP
Click Start, Run, and type the following into the Open field: regedit
Click OK. The registry editor appears.
In Windows XP, click File, Export, type a filename that is easy for you to remember, and click Save.
In Windows 2000, click Registry, Export Registry File, type a filename that's easy for you to remember, and click Save.
A copy of the registry has saved for back-up purposes.
Click the plus sign (+) next to the following items in the list:
•CurrentControlSet (or the current control set with lowest number if that is all that is listed)
Select 4D36E965-E325-11CE-BFC1-08002BE10318.
Select UpperFilter in the right window and press the Delete key.
Confirm the deletion by clicking Yes.
Select LowerFilters in the right window and press the Delete key.
Delete all other UpperFilter and LowerFilter values within the 4D36E965-E325-11CE-BFC1-08002BE10318 key.
and then restart the comptuer
even if this thing doesnt work replace the drive!!!
Posted on May 18, 2008
  • 376 Answers
SOURCE: region code
Press the Home button
Choose SETUP
Scroll down to the LOCK icon
Press ENTER (you won't see any response.)
Press the 0 key 7 times
A message will appear congratulating you on bbeing region free - press Enter.
Posted on Aug 07, 2008
Activate secam option
The recorder is not SECAM compatible - can't be selected.
May 13, 2017 | LG RC389H DVD/VHS Recorder
Pick up assembly
end of life or needs optic cleaning.
fiddling inside , will make it worse. RTM, the service manual.
did you contact LG for parts.
did you look in mCM electronics? they sell sub assembles.
Sep 29, 2013 | LG Computers & Internet
LG 42LM640T turned itself off during an app update and now will not turn back on, it is stuck on the LG welcome screen.
im guessing it was the same problem as my lg rht498h dvd recorder , a bad capacitor on the power board if you have or know anyone with electrical or electronic knowledge it will only cost a couple of pounds to repair you can order the replacement capactors online , ,open the back up and look at the power board for damaged leaking or bulged capacitors then make a note order a new one and replace making sue you line up the dot on the board with the line on the capacitor it will only take about 20 mins to do , hope it helps and good luck
Apr 09, 2013 | Cell Phones
LG RH278 DVD recorder has no power after power outage
The power supply regulator board should be troubleshooted. It will be best to replace this board as card basis, rather than making surgery to it. You can bought this board fro the authorised service center for LG at your town.
May 16, 2012 | LG LDA511 DVD Player
I need an Ownwers manual for a LG HDD/DVD Recorder mod HR278
Try this link- RH278. They are going to ask you to rate the product first before downloading the user guide.
Nov 27, 2010 | LG Audio Players & Recorders
I have more or less the same problem. My HHD/DVD Recorder RH278 does not read ANY CD or DVD, which were previously playing fine in the same player. Would it help to replace the laser tray and WHERE DO I...
Usually, the problem is condensation on the electronic circuits. LG has a fan which moves hot air out. If you turn on the recorder, it will get hot and dry out the moisture over time. Then the DVD will read the disk and do recording too. You may also be able to play music cd to dry out the way to fix it, is to turn it on but not use it for a while.
Nov 21, 2010 | LG DR787T DVD Recorder
My LG RH265 keeps opening the tray. When I close it with the remote, it opens itself again. This problem repeats itself on and on. What can I do about this, is there a way to reset the recorder?
My RH265 has had this fault three times and on each occasion LG have replaced the 815V DVD Deck (Part No. EAZ34934813) - This fault seems to be common to all their recorders and in my view gives LG an otherwise undeserved very bad name for product reliability. I am very surprised that they do not appear to have solved the problem with a reliable component.
Dec 06, 2009 | LG RH177 DVD Recorder/HDD Recorder
Hi, I have exactly the same thing. Happened before but went away when I got bored trying to fix it. This time I phoned LG support and they said take it back to Comet (they have bought out their servicing). End of conversation. Polite but firm.
Appalling support via their websites, appalling products. Never again.
Oct 05, 2009 | LG DR787T DVD Recorder
Computers & Internet Logo
94 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
