Is Cpu installed correctly ? easy to bend pins on X2's...
using a flat screwdriver make a connection between 2 pins on PWR only, disconnect everything else exept Mobo to do this just to see if you get boot to Bios, alter jumpers as you go
If you mean the plastic plug jumpers located on the hard drive to set master . master/slave ........ single or master ::::: master with slave ::':: slave :::': note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
The jumpers should be printed on top of the hard drive. If its not booting at all it might be the ram or leads from motherboard to hard drive.
Test all power and data leads that attach to your hard drive IDE,SATA the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
Reboot the computer, and carefully watch the screen.
One of the options should be to access the "recovery partition".
Press the listed key to boot from that partition,
and to "restore" your software to the "factory" level.
They have the new drivers on their website. Updating the drivers might fix your issues. Just type "acer aspire M3100+Drivers" into google and it should be your first option.
