Nokia N97  Cell Phone Logo
Anonymous Posted on Oct 14, 2011
I have a nokia N97 it is completely dead. does not switch on - when on charge the only thing that happens is the nokia screen appears but nothing ells not even the battery meter. i have updated all software on the phone. now i am a bit worried about all my data on the phone i realy do not want to lose. please help.
CHETAN PATEL
Level 2:
New Friend:
  • Expert 97 Answers
  • Posted on Oct 18, 2011
CHETAN PATEL
Expert
Level 2:
New Friend:
Answers
97
Questions
0
Helped
14942
Points
239
Hi
try connect your phone with the nokia pc suite and try to back up see if it can let you do it.
thanks
1helpful
How to unlock Nokia 97 with the unlock code?
Hello. Are you asking the unlock code for a Nokia N97? if so, you can get the accurate unlock code from ClassicUnlocking.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia N97 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N97.
3 - Compose #pw+CODE+1#.
4 - The Nokia N97 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N97 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia N97
tip
Nokia N97 mini Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Nokia N97 mini mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N97 mini mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia N97 mini without any sim card.
2 - Don't bother as to what is displayed on your Nokia N97 mini.
4 - The Nokia N97 mini would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N97 mini mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia N97 mini
Each Nokia N97 mini mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia N97 mini mobile phone from the site http://www.unlock-zone.com/
Nokia n97 charging solution
Hi If the USB Socket (usb board) found no damage the only thing is to apply jumper.So, you can contact nearest mobile repairing shop or follow this link N97 charging solution.Thanks for visiting fixya
Hi, I am facing problem in getting my new Nokia N97 recharged. When i turned my Mobile Off the charging light on left side appears very bright and Mobile gets charged properly. but when i turn it on and...
this issue is generated from some types of software problems, you need to get back to Nokia dealer and they will solve you the problem in a seconds
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
4helpful
2answers
N97 wont update software
hello how can change clone nokia n97 operating system for work complete with wifi n internet etc
1helpful
The Nokia N97 wont start working. I press the power button to turn on, and the screen stay with NOKIA on it and does not go forward. Just stays with freeze NOKIA sign on it. Does anyone has any idea how to...
if your set have a warrenty better to service at nokia showroom donnt do anything its not just like an ordinary nokia if it like an ordinary nokia then i can help you ok
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
