Question about Goodman CKL60AR60 Air Conditioner
Goodman Air unit - Blower Fan will not kick on
Goodman Packaged Air Unit about 10 years old. Unit will run through a good cycle for a while, then the unit will kick on and pull air into the system but the blower fan will not kick on. Removed blower fan and had it tested and all checked out. Re-installed blower fan and gave the unit a good cleaning only for it to start again two days later. Is there a blower relay that could be bad? Any help is appreciated!!
Same problem....any solutions yet?
Posted on Nov 12, 2008
I have a 7 year old Goodman. The indoor unit blower keeps cycling on / off (it will run 5 to 10 mins them cycle off). The house is 81 degrees and the t-stat is set at 70; the condenser unit is compressor...
Make sure the capacitor is the proper microfarad rating for the motor you have. Sounds like the motor may be drawing too many amps and dropping out on it's overload when hot, then when it cools it turns back on.
Jun 04, 2012 | Heating & Cooling
I have a Goodman PH030-10 packaged Central Heat/air unit electric temp outside is mid 30's it is 58 in the house and the unit is not shutting off, coils are clean the blower motor is running. I opened the...
I would have the charge checked and also have the electric backup coils checked....
It seems athough you have multiple problems.....
heatman101
Dec 27, 2010 | Heating & Cooling
I have a goodman ar24-1 blower motor that will not start. I have changed the capacitor, checked the thermostat, spun the blower motor but still will not start. Outside unit runs but no blower. Any ideas?...
Check the relay or sequencer that controls the blower if it has one of those. If the fan is controlled by a circuit board then you problem may be there. If it is controlled by a circuit board then you can check for power at the fan connection when the fan is supposed to be on. Then there is always the possibility that you blower motor is burned out. You can use and ohmmeter to check the motor windings. You said you checked the thermostat, how did you do that? If you install a jumper between the R and G connections the fan should run if everything else is OK.
Nov 14, 2010 | Goodman CKL24AR24 Air Conditioner
The compressor outside is running but the fans inside are not blowing. Our Goodman unit is only 2 years old.
sounds you like you got a blower problems could be the motor or the run capciator. You can turn off the power and ohm the motor out it should have a reading between the wires if yu get infinity its open same on the run cap unhook the wires and run an ohms reading it should build up and then fall back toward zero. You can also check the microfards if your meter reads this. Look on the cap it will tell you the microfards and it shuld read close to that reading. Good luck!! I hope I have helped you.
Jul 10, 2010 | Goodman CKL60AR60 Air Conditioner
No AC
Turn off power, if this is a complete outdoor unit, remove the blower door Turn Unit back on see if the blower motor is working. If belt driven belt is loose or off, if direct drive and the fan is not working, its possible the capacitor is bad or fan is bad.
If fan is operating, then either a damper is closed, something is obstructing the duct or it is at to low
of speed.
Jul 02, 2010 | Goodman GPC1342H21A Air Conditioner
Hi, just replaced the capacitor thinking that would solve the problem but it appears it did not. The motor outside would kick on the unit inside would kick on but the blower motor inside works sometimes...
Turn off the power to the air handler(indoor unit). Remove the access panel. From the motor,trace the wires back to the fan relay. One wire will probably trace back to the incoming power terminal. The other is the fan relay. It could be intermittent thermostat signal to the relay or a bad relay.
To verify if the fan motor is good,you can remove the one wire from the relay and re-attach it to the other side of the incoming power terminal. If it runs OK there,replace the relay. If it does not run,replace the blower motor.
Sep 28, 2009 | Heating & Cooling
Hello, We bought a Perry Home in Georgetown TX last March and it is still under its two year warranty. Our air conditioner stopped cooling today. It has been working well for over 1 year. We came home...
You have a 10 year warranty on your AC. Call a Goodman rep and have it serviced. It will probably be a bad compressor capacitor. Bad wire or no refrigerant.
Jun 26, 2009 | Goodman Heating & Cooling
The outside unit runs but the inside doesn't blow
COUL BE A FAULTY BLOWER RELAY BOARD OR THE MOTOR COULD BE GETTING HOT AND SHUTTING OFF ON OVERLOAD. CALL A CONTRACTOR
Jun 16, 2009 | Goodman CLJ36AR42 Air Conditioner
Goodman Model CK60-1C with White Rogers mercury tube thermostat
The contactor on the outside unit is sticking and must be replaced. The inside unit cycles off and the outside continues to run causing the refrigerant lines to freeze up.
Jul 29, 2008 | Goodman CKL60AR60 Air Conditioner
Blower fan keeps shutting on/off,
Your blower fan turning on and off shows your thermostat is working. I am willing to bet you have the fan in the automatic condition. Check for a sticking contactor at the outside unit.
May 31, 2008 | Heating & Cooling
Goodman CKL60AR60 Air Conditioner Logo
469 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
