Question about Delta 989-SSSD Allora Kitchen Pull Down Faucet with Soap Dispenser Brillian...
Delta 989-SSSD soap dispenser loose.
How do I tighten my soap dispenser to my granite countertop?
I can reach up behind the sink and turn the soap reservoir, and feel a ring with nubs extending from the ring. I can't seem to find the two parts that need to be screwed tight.
Thanks for your help.
Tom
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi tsquared_030,
I'm Harvey the Master Plumber.
Your problem is: How do you tighten your soap dispenser to your granite countertop?
You can reach up behind the sink and turn the soap reservoir, and feel a ring with nubs extending from the ring. you can't seem to find the two parts that need to be screwed tight.
You will need a little help. First remove the top dispencer, it just pulls out. Time to go below. Carefully unscrew the soap bottle to get it out of the way. Have your helper hold the escuchen (the part on top) while you tighten that nubby ring underneath. I find it easy to do this with a basin wrench. If you can't lay your hands on one you'll have to make do with your hand but you won't be able to fully tighten and you may have to repeat in future. Have fun.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
Why is my grohe alira kitchen faucet loose on a granite counter
Probably a loose fixture nut under the counter behind the sink.
Yeah ya gotta pull out everything and crawl up into the cabinet on your back and see if the nut (right up at the granite, above the hot and cold inlet pipes) is loose. If it is THEN you'll need to tighten it. Wrench, slip-joint pliers or a basin wrench. (probably basin wrench which is a specialized tool made for reaching up into tight places)
Aug 31, 2014 | Grohe Alira Pull-Out Kitchen Faucet S....
Dispenser working but had new granite counter installed and it is now thicker. Need a longer shaft to screw soap dispenser on u der sink
Take both pieces to hardware store they may have the top only. If not, they sell soap pumps made for granite counters.
May 09, 2012 | Moen Soap & Lotion Dispenser 3910S
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
Purchased soap desp. model #RP47280SS with no directions. Left white ring with dispenser on counter and used rubber washer and plastic nut on bottom. I can't get the dispenser very tight to the...
bobj50-
The white washer goes underneath the counter (with the nut) and the rubber gasket on top of the counter under the dispenser head. You may find it easier to tighten the assembly with this configuration. As for filling the bottle, unfortunately it must be unscrewed from under the counter in order to refill it.
Hope this helps.
Regards,
DIYpro
May 17, 2011 | Delta & Soap Dispenser
Delta single handle pull-out sprayer loose from base. How to tighten it?
Pull out sprayer has a plastic nut to tighten under countertop. You should be able to reach underneath and hold the top while tighting the bottom.
It designed to be tighten by hand to avoid damaging.
May 19, 2010 | Delta Faucet 470-DST Signature Diamond...
Do i really love james recabo
It is possible, though love is a tough thing to truely understand. Ask yourself, can you see spending everyday with james recabo? Are you happiest when you are with james recabo? When you and james recabo are apart does it feel like and eternity before you see james recabo again? If you answered yes to all these questions, then it is possible that you might love james recabo. Hope this helps
Mar 29, 2010 | Delta 989-SSSD Allora Kitchen Pull Down...
Good morning my plummer put in my new 980t sd -dst touch 20 faucet....it works so far....however my pull down hose i have to some what push it back up for it to go in......on the video it looks like it...
If you can, look up under sink for hose attached to faucet. There should be a weight on the hose, to assist in retracting it. Usually just a bolted on round lead weight that wraps around the metal sleeve of the hose. Perhaps he forgot it, or it needs to be moved/adjusted by loosening off the bolts that hold it together and sliding it up or down the hose. He may have even routed hose wrong. Have someone pull it out and slide back in while you watch it.
Jan 22, 2010 | Delta 989-SSSD Allora Kitchen Pull Down...
Delta 473 faucet very loose where it meets the granite
This is a view from the underside of our sink. Is this what you were talking about? The steel plate is W-shaped (upside down in this case) and has a single nut larger than 3/4". It's almost impossible to fit a wrench up there to tighten it.
Jul 30, 2009 | Delta Model 473: Saxony Kitchen...
Delta 989-SSSD Allora Kitchen Pull Down Faucet with Soap Dispenser Brillian... Logo
616 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
