Question about Motorola Mobility RAZR V3
Sd card how do i veiw video from my sd card on my v3xx?
    Brigadier General:
  • 7,752 Answers
Select the video in the card and view or play them as usual
Posted on Sep 24, 2008
4gb micro sd card wont upload or show images
hi buy a card reader cost about $5 dollars on E/BAY plug it into youre mac & put the sd card in & hope it all works ...cheers..
Apr 06, 2017 | PNY Electronics - Others
UNABLE TO ACCESSMY 4GB MICRO SD CARD
Your memory card reader lacks SDHC compatibility. You must either update your pc card reader to one which is compliant with SDHC or use a cheap external card reader to do the job.
SD and SDHC cards look the same and fit the same slots, but they have significant technical differences which older readers cannot handle.
Jul 22, 2010 | SanDisk 4GB microSDHC Memory Card
How do I load pictures from San Disk SD Card onto
do you have a card reader on your laptop? if so slide it in, wait for windows to recognize, then veiw all files, after that highlight and copy to wherever you want them to be stored
Jul 03, 2010 | HP VM114UA notebook
Device not reading sd card loaded music
try putting sd card back into a pc and check that the write protection is turned off. also if it has a write protection switch on the side of it it will need to be off. failing this. you may need to check what format the sd card was formatted in . it will need to be ntfs formatt not fat32. if it is fat32 ,save whats on it re format to ntfs then reload your files. try again.. cheers Phixxer.
May 24, 2009 | Garmin NUVI 360 GPS Receiver
I bought a memory card for my v3xx razor phone with At&t i do not know how to get it to work. I do not have a camera to put it in to take a picture. How can I do it with my phone only?
You must not have a v3xx, because the v3xx uses a mirco sd card
and the slot is next to the sim card slot.Also the v3xx has a camera,
and there is no option to get this model without a camera.
The v3 does not have a memory card, but has camera also.
If you do find the slot,if you have a v3xx,then go to your menu and then open connection, then open,phone status, then scroll down to
storage devices,open it, should be left top button, pick options,now you should see,details,rename,format, format the card, this should allow the phone to see the card. There are some brands that just don't work with a phone. I have always used kingston. I have around 12 different type's and they have always been a great card.
Feb 17, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Micro sd card
yes 4GB is the maximun motorola specifiy using on the v3xx
Jun 23, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola V3xx I-mode
Under the settings for usb connection type change the setting to memory card connection. This is subject to having a memory card (Micro sd) installed. Otherwise you may have to install motorola phone software into your computer and use this to update files on your phone.
Regards,
David M-G
Feb 20, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Panasonic TH-50PX60U 50 in
Try to open the back cover and remove the SD card cable from the connector.
Dec 28, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Motorola razr v3xx
it would be best to go have the phone firmware reflash and the card reformatted.
Dec 14, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Motorolla v3xx trouble shoot directories
Try this:
SETTINGS>Initial Setup>DTMF>select "SHORT"
Motorola Mobility RAZR V3 Logo
23 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
