Question about Microsoft Windows Vista Ultimate Edition
Cisco VPN Client for 32 bit vista
I had installed VPN client software version 5.0.01.0600 and it was working ok - only thing is if i shut down my laptop the registry files get deleted and i will have to reload VPN client.
But now ther is some conflict and it is not working. When i try to unistall this version there is a error mesage - " Error 28000 / 1721 theer is a problem with this windows installer package. A program required for this install to complete could not be run"
Please help me.
    Problem Solver:
  • 12 Answers
Download the latest version of the Cisco VPN Client. My version is 5.0.03.0530.
You can also try using the Microsoft "MSIZap" utility to ensure a clean uninstall. It is a command-line utility. You will need the original MSI install file from the Cisco VPN client to use MSIZap.
You can download it here: http://msdn.microsoft.com/en-us/library/aa370523.aspx
Posted on Sep 22, 2008
Cisco expert
I think you're confused. IP Communicator is the unified communications client (IM and Phone) It is looking for a capatible headset so you can use your softphone. This software is not your VPN client. There are two different cisco product: one for your VPN and one for your phone. If you're trying to ocnnect to an old-style Cisco VPN, your IT dept will have to configure that with a certificate.
Solution from Cisco: http://www.cisco.com/en/US/products/sw/voicesw/ps5475/products_tech_note09186a00809b6c40.shtml
This behavior is observed when a user attempts to install or use the IP Communicator on a system that has different names for the Playback (wave out) and Recording (wave in) devices.
In order to overcome this problem, perform one of these tasks:
-Use a USB headset that is recognized by the IP Communicator.
-Upgrade to the latest version of the IP Communicator
Nov 07, 2013 | Arris SURFboard SBG900 Wireless Router...
Have error 442 with cisco client vpn 5.07 on windows 7 - 32 bit - any ideas?
Error 442 - Failed to enable virtual adapter.
No fix yet from Cisco. Try this work around.
Run cmd as Administrator and execute the following command:
reg add HKLM\System\CurrentControlSet\Services\Tcpip\Parameters /v ArpRetryCount /t REG_DWORD /d 0 /f
Mar 24, 2011 | Cisco Systems Cisco VPN Client
I installed the printer and share it. It is only available to user who are on x64bit. user with 32 bit win xp cant access it and install/share it. I have tried to download and install x86 driver but...
This is the HP solution for the problem
HP LaserJet, Color LaserJet and LaserJet MFP Products - Print driver Client / Server Connections in a mixed 32-bit and 64-bit environment ISSUE: 32-bit clients are not able to connect to shared Universal Print drivers or discrete drivers on a 64-bit print server or vice-versa. These scenarios may involve Server 2003/Server 2008 64-bit print servers with Windows XP, Vista, 7 32-bit clients. It is also possible that the server editions could be 32-bit versions with 64-bit clients. SOLUTION:
  1. The administrator will need to download the 64-bit AND 32-bt version of the print driver from www.hp.com . If the server involved is a 64-bit version, the 64-bit version of the print driver will need to be installed and mapped to the printer via TCP/IP. Ensure that the print driver has been shared on the network by going to the print driver properties and enabling Share this printer within the Sharing tab. c02030528.gif
    Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
  2. Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
    This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button. c02030529.gif
  3. Once the administrator clicks on the Additional Drivers button, the next screen will allow the administrator to load the 32-bit drivers by placing a checkmark in the x86 button and clicking the OK button. c02030530.gif
  4. Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
    For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf. c02030531.gif
    Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
  5. Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
  6. Once the client maps to the shared print driver, printing should work successfully.
    For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
Mar 17, 2011 | HP Laserjet P4515x Printer
Hi, when i try to install cisco vpn on my xp machine, it is throwing 1721 error.
Cisco VPN Client for Windows Vista, release 5.0.0.340, does not support the following:
blank.gifMicrosoft Windows NT, 98, and ME.
blank.gifSystem upgraded from Windows XP or earlier Windows operating systems to Vista. (Clean OS installation required.)
blank.gifCombination of Cisco Unified Video Advantage 2.1.2 and McAfee HIPS Patch 4 Build 688. To avoid system failures, uninstall either of these two applications, upgrade McAfee to the latest version, or use VPN Client 4.6.x.
blank.gifStart Before Logon.
blank.gifSmartCard authentication.
blank.gifIntegrated firewall
blank.gifInstallShield.
blank.gifAuto Update.
blank.gifTranslated Online Help. Online Help is provided only in English.
blank.gif64-bit Windows operating systems. For x-64 support, customers should explore with their Cisco sales representative the use of the next-generation Cisco AnyConnect VPN Client.
Nov 04, 2010 | Microsoft Windows XP Professional
Cisco VPN Client Error
Hello
Try to switch off the Cisco VPN Stateful firewall.
Apr 19, 2009 | Computers & Internet
Vpn client
This router has built is VPN software that allows VPN from anywhere in the world. There would be no need for a software based VPN
Jan 15, 2009 | D-Link DI-804HV - 4-Port Broadband VPN...
Vpn client
You can download the MU VPN client at www.watchguard.com/support
For instructions on how to install and set it up, this document should be helpful http://www.watchguard.com/help/docs/v50SOHOMUVPNGuide.pdf
Nov 05, 2008 | WatchGuard Technologies WatchGuard Firebox...
Exchange server access problem.
If your cisco vpn client is behind the natted device then you need to allow nat traversal in the head office firewall and if you connect the vpn client through data card it will connect,
Aug 01, 2008 | D-Link NetDefend DFL-700 Firewall
Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Dec 31, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
Microsoft Windows Vista Ultimate Edition Logo
1,369 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
