Question about HP Photosmart 945 Digital Camera
HP Photosmart 945 digital camera problem. Love this camera. Can someone help me? The lens is extended and it won't power down. I've taken the batteries out, replace them. But all that happens is a red light comes on. Please help me.
    Brigadier General:
  • 11,967 Answers
Go to this website:http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Oct 14, 2011
SOURCE:
Camera won't remain on
It's probably a lens related problem. Blow through the lens to remove any debris stuck inside. Or tap your camera repeatedly while the lens is facing the ground.
Aug 14, 2012 | HP Photosmart R927 Digital Camera
I have a Lens Error M425-12 on my Photosmart M425 camera. Can this be fixed?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 26, 2011 | HP Photosmart M425 Digital Camera
Lens error please help HP Photosmart M627 Digital Canera
Oct 12, 2010 | HP PhotoSmart M627 Digital Camera
Hp945lens
Hi Do you use a lens tube? You need one of these so the lens does not hit the screw on lens when it extends. Quite cheap on ebay etc. Standard 55mm thread.
Hope this helps
jbrevealsall
Jan 21, 2008 | HP Photosmart 945 Digital Camera
Flashing Light
I have had a HP Photosmart 945 for a few years now. A few days ago was the first time I saw my camera experience the problem described above. I thought something is wrong with the on-bard logic.
Replacing my batteries (4x2300mAh NiMH AAs) with four other freshly charged batteries of the same kind didn't fix it. The camera's LCD kept flashing on and off for almost an hour until my family got tired of it and turned it off by removing the batteries.
I just replaced the rechargeable batteries with four regular alkaline batteries and now suddenly it works. Go figure.
The moral is that changing the batteries sometimes helps. When it works, it will get your camera going for a while. The problem, however, doesn't seem to be battery-related or I would have seen it a long time ago with smaller-capacity batteries like alkaline AAs. Something is very wrong with the camera itself, that much is clear.
Best-case scenario now is that I have an unreliable camera that can give out at any moment. For example today it died in mid-shot and almost spoiled a family event. For me the solution was "get a non-HP camera".
I hope this helps someone out there.
Dec 19, 2007 | HP Photosmart 945 Digital Camera
Can u help??
Change the bateries. Replace it with new acc.
Oct 13, 2007 | HP Photosmart 945 Digital Camera
Camera won't work
HP technical Support is the 1st place to go - in case there is a repair/replacement solution. If the camera is over a year old - an economical repair is unlikely
Jul 09, 2007 | HP Photosmart 945 Digital Camera
Need Help!
Sounds like this camera will need inspection and repair by HP. Since it was expensive, it might be worth doing, so I would send it directly to HP (find out where and how at their website). Pack it in several layers of bubble wrap, not packing peanuts! HP should offer you an estimate for cost of repair, or possibly a trade-in. Good luck.
Jun 16, 2007 | HP Photosmart 945 Digital Camera
HP Photosmart 945 Digital Camera Logo
129 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
