Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
RPL & TPL tones used in T-5720
Please advise what are the Interference Eliminator Codes (RPL & TPL tones) used in T5720.
I have a Motorola GP-2000 UHF/FM handheld radio, set it at Ch.2- 462.5875 Rx/Tx but cannot get it to communicate with the T5720.
Please advise.
Thank you.
  • bobscu Mar 21, 2009
    I'm trying to use a set of 5720 with a set of 5622. Channel 5, eliminator 0. checking the frequency ranges on both models they appear to be incompatible. Am I correct that these sets cannot interopperate?
  • Motorola Master
  • 1,654 Answers
The T5720 user manual does not list the TPL codes possible in the radio. However, they are the standard list, with zero being "open squelch" (no code). Here is a link to a Motorola manual which has a list of the PL codes in order on page 43.
On the T5720, another item to what for is the Qt noise filter. Be certain to set it to zero unless using the T5720 with others of the same model. It can also block transmissions. Here is a link to a user manual for the T5720
Posted on Sep 22, 2008
What are the 3 interference codes
There are many interference codes available on most radios. The types would be PL (private line) and DPL (digital private line), and sometimes PL will be referred to as TPL (tone coded private line).
Best regards.
Jul 27, 2014 | Motorola Radio Communications
One of our two radios (Motorola T5720) recieves but when you go to talk to someone else they cant here you. I have made sure that we were on the same channel.
Check your Code (interference eliminator code) and your Qt filter (if any) to see if they match the other units.
Best regards.
Aug 29, 2011 | Motorola Talkabout T5720 (7 Channels)...
Can motorola talkabout T5720 FRS/GMRS talk with Motorola GP338 UHF?
Your GP338 would need to be reprogrammed to one or more of the frequencies available in the T5720. If you are using the interference code eliminator, it would also need to be programmed into the GP338. Take your GP338 to your local Motorola dealer for reprogramming.
Here is a link to the user guide for the T5720, where you will find a list of frequencies: See page 19.
Best regards.
Feb 23, 2011 | Motorola Talkabout T5720 (7 Channels)...
I want to communicate from t5720 talkabout to midland lxt303. When I set them to the same channel the talkabot gets out but will not receive unless I press the MON button on the face of the radio
Set your interference eliminator code on the T5720 and the Qt filter both to zero. You have one or both turned on. By setting them to zero you will turn them off. Then your radios should work together.
Mar 14, 2009 | Motorola Talkabout T5720 (7 Channels)...
Go to the manuals here should get you going. if not find someone with a frequency counter. this is alot easier than getting software for the radio.
Oct 02, 2008 | Radio Communications
What will i do to connect Motorola T5720 and T5728
Set both the frequency and the interference eliminator code to match one another. (The big number and the small number) Here is a link to the owners manual:
Basic instructions:
Press the Menu Button
The freq number will flash
Use the + or - button to select the frequency.
Press the PTT button to save the channel setting.
To set the code:
Press the menu button until the code starts to flash (the small number)
Press the + or - to select the code.
Press the PTT to save the code setting.
Once you have both radios matching on frequency and code, they should communicate together.
Aug 21, 2008 | Motorola Talkabout T5720 (7 Channels)...
Model 5710
You need to check your programming of both frequency and interference eliminator. You may not have your radios set to match one another.
Jun 27, 2008 | Motorola Talkabout T5720 (7 Channels)...
Hello gc0273,
Make sure that both radios are using the same Interference Eliminator Code. The situation you describe sounds like one radio has a Interfernce Eliminator Code activated and the other radio does not.
To access the Interfence Eliminator Code setting on this radio press and hold the MENU button until the code starts to flash, then use the + or - keys to adjust the setting and press the PTT to save it.
Best Regards
Agent Ken
Go Ahead. Use Us.
Mar 02, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
746 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
