Question about Frigidaire FEQ332E Electric Dryer
Dryer problems My dryer started squealing during the drying cycle. It would turn for a few minutes and then it would stop turning. I have to divide in half the load just to get it dried, whereas it used to do a full load. Thanks for your help. Joanne
    Sergeant:
    Champion:
  • 324 Answers
Either the rear bearing or the idler is worn, my thoughts would be the rear bearing.
Posted on Nov 01, 2008
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Dryer beeps during dry cycle
if the dryer is beeping on it's own most likely you have a bad board part WP8563974
Oct 28, 2017 | Whirlpool Cabrio WED6400SW Electric Dryer
My dryer will run for about 20 minutes and then shut itself off. I cannot turn it back on for at least an hour as the 'done' buzzer will buzz and the dryer will not turn back on. Does anyone have any...
If it happens during the auto-drying cycle, the moisture sensor could be faulty.
If it happens during the timed cycle, the operating thermostat may be faulty. A faulty operating thermostat can fail to turn the heaters off and allow the dryer to get too hot. When this happens, the high limit thermostat will turn off the machine. After it cools down, it will start again.
Apr 28, 2010 | Dryers
Dryer turns off before cycle finishes
if unit has auto temp control,you may have a bad thermistor,,,,,make sure door is latching tightly,could be pushed open during cycle stopping it
Mar 03, 2010 | Whirlpool LER5636P Electric Dryer
My Whirlpool Gold dryer makes a high-pitched squealing noise for about 5 minutes when first turned on, then stops and dryer continues cycle. The noise doesn't sound like metal on metal but more like a...
CHECK BELT,TENCHEN ARM (KEEPS BELT SNUG),ALSO ROLLER WHEELS...
SOMETHING IS GOING BAD BUT ONCE IT WARMS UP IT STOPS MAKING NOISE.
YOU NEED TO FIND THE PROBLEM BEFORE IT BREAK DOWN???
LATER FREDDY
Feb 11, 2010 | Whirlpool Dryers
Dryer stopped working during cycle
is dryer drum turning u might be amotor are some other problem you may want to call a service tech to fix your dryer ok
Oct 21, 2017 | Maytag Performa PAV2200
Whirlpool dryer
If your dryer stops during its cycle, wait ten minutes and start dryer again. If dryer starts, then the motor was overheating.
Solution, Check for lint blockage around the motor and for possible overloading. If dryer repeatedly stops during its cycle, especially during consecutive loads, replace motor.
Good luck
Aug 10, 2008 | Whirlpool LER5636P Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Frigidaire FEQ332E Electric Dryer Logo
112 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
