Please take a good look at the front of your printer and make sure that the only thing blinking is the exclamation point. If it is then it means that the cover to your printer is not closed all the way. Try opening and closing the printer to cancel this error.
If there is a picture of a sun, an ink droplet or anything else along with the blinking exclamation point then the error can mean different things.
the sun light and the deum icon +error message ! sign are both blinking on my Dell 1710
i have changed the toner drum but it keeps blinking should i have to change the inside drum too. because the last time it stop working paper rolled over it..still wondering what other different it is or might be? shall i change the inside drum too?
Did you reset the counter after you replaced the drum? To reset the counter press and hold the cancel X button until all the lights flash in sequence. Try that and see if it solves your issue. Report what you find and I will continue helping until this is solved.
