Question about Mercury P4VM800M7 Motherboard
Bios boot probleme
When a switch on my system only the processor 's fan run.
the post beep sound does came and anythings appear on scream
pls help
  • kouameherman Sep 22, 2008
    when a switch on my system only the processor 's fan run.
    the post beep sound does not came and anythings appear on scream
    pls help
  • 52 Answers
Your windows might have gon corrupt or your motherboard has a hardware problem so you should contact your manufacturer
Posted on Sep 27, 2008
How will you know if the processor is still working?
Finding Out the CPU condition whether its working or not
  • 1
    Turn on your PC and listen for a beep. Your computer runs a diagnostic upon startup called "post." Post checks for the basic requirements for your system. This includes RAM, processor and video functions. If those three basic elements are working properly, you will hear one beep from your computer's speaker and you can be assured your processor still works.
  • 2
    If you hear multiple beeps, count the number of beeps you hear as this will help you determine if your processor is functioning properly. If you are running Phoenix BIOS, make sure you count and write down the beep sequence.
  • 3
    Consult your motherboard's BIOS instruction manual; there will be a section on the "post" startup. Five beeps means a processor error for most standard AMI BIOS systems. The number of beeps you here will tell you the problem your computer is experiencing that is preventing it from booting up. Once you know how many beeps to look for, you can safely determine if your CPU is still functioning properly.
  • Jan 19, 2011 | Intel Pentium 4 2.40GHz 512/400/1.5V...
    I ve a compaq cq60-220us.. when i switch it on. it shows compaq display then it starts shouting a loud beep sound... wat do i do....... pls help...
    this beep can mean anything as they are warning tones while bios checks up your system while booting. So there must be something wrong with your system hardware and in different systems different kind of beeps means different hardware problem. So 1 way is to contact lenovo customer support or take it to lenovo repair centre.
    You can't do anything on your own.
    Jan 02, 2011 | Computers & Internet
    Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
    I still did not find beep code that match your problem..
    Anyways here are the common beep codes for your motherboard.. it might help you too.
    1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
    2. 1beep - board is working fine.
    3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
    4. 1short beep - system boots normally
    5. 2short beeps - CMOS setting error.
    6. 1long 1short beep - dram error
    7. 1long 2 short beep - video card or monitor not connected
    8. 1long 3 short beep - keyboard error.
    9. 1long 9short beep - ROM error
    10. Long beep - memory card is missing or not connected
    11. Short beep - power supply error
    12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
    Hope this gave you an idea of your problem..
    Much appreciated if you rate this help..thanks..
    May 23, 2010 | Abit AV8-3rd Eye Motherboard
    Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
    Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
    Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
    Computer when turned on will not boot and makes a long beep continuously and then makes like a siren sound
    The long beeps probably mean a problem with RAM. So try replacing it. Check whether the CPU Cooler (the fan on top of the processor) is working. If the fan is not working, the processor gets hot, and a siren sound is emitted. Also check whether power unit fan (at the back) is working. If RAMs are replaced and you still get the beeps, the problem may be with the VGA. (The beep sounds help to identify the problem, but the sounds differ with different BIOS models).
    Jul 30, 2009 | Computers & Internet
    Pc not on
    Please list the name & model number of the motherboard.
    M
    Jun 09, 2008 | Computers & Internet
    Power supply change seems to have killed it.
    BIos Beeps or Post-Codes Differ from Manufacturer to manufacturer.
    1 Long Beep Usually Refers To The Dram Refreshing ( Faulty Or Incorrectly Fitted Memory Modules )
    Try 1 Memory chip in each slot individually.
    Also ensure Your Graphics Card, Is Correctly Seated, not uneven. especially If it,s An AGP Card.
    Hope Tjis Is A Fixya For You.
    Mike @ compurepair.
    Feb 25, 2008 | Gigabyte GA-K8VM800M Motherboard
    New Acer Aspire E700 does not load-up
    Does your BIOS POST runs then you might be having a Disk Booting Problem, If you dont see your BIOS POST Screen, then check if you can hear any beep sounds, If you hear beep sounds check the ram whether it is properly inserted in the ram slot or the ram might be faulty.(You may have to change the Ram). If you dont hear any beep, check whether the buzzer(Speaker in the CPU) is working, If buzzers were working fine before, then you might be having problems with your mother board or processor. If you know how to work on such problem try reinstalling the processor, ram etc in the cpu . Otherwise call a service engineer to have the job done.
    Jan 01, 2008 | Computers & Internet
    Intel 845 GVSR
    90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
    Nov 11, 2007 | Intel Motherboard
    Mercury P4VM800M7 Motherboard Logo
    67 people viewed this question
    Top Mercury Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    Abhinandan  Patil
    Abhinandan Patil
    Mark Taylor
    Mark Taylor
    Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
