Question about Canon Cameras
My Canon Sure shot will take a photo or two, then the error "memory card error" shows up. I've tried using new memory cards, formating, but still the error message. What can be up? Thanks so much.
  • 9 Answers
SOURCE: memory card error - E50
Error Code "E50" (CF card formatting error) When a camera error occurs, an error code like "Exx" will be displayed, where the x's represent numbers. The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. If the same error occurs when you are using the CF card supplied with the camera, please contact the retailer where you purchased the camera or the nearest Canon service center. If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded. Precautions for handling a CF card: - Do not remove a CF card or disconnect the camera's power source while the camera is recording, loading, or erasing data on a CF card. - CF cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration. - Do not attempt to disassemble or alter a CF card. - Place the CF card in the supplied case for storage. - Moving a CF card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the CF card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condensation forms on the CF card, put it aside until the water droplets have evaporated completely. - Do not use or store CF cards in the locations subject to dust or sand, high humidity, or high temperatures.
Posted on Aug 11, 2005
Richie_asg1
  • 1036 Answers
SOURCE: I have a brand new
Hi ,
You could try this Card recovery software - free to download CLICK HERE
If the card is new and still under a manufacturers guarantee - I would try for a full refund on it. They do fail with increasing regularity, so in future I would opt for smaller capacity cards.
I have not found out yet if the failures are due to mechanical faults, handling damage, electrostatic discharges or simply instability of the chip. In theory they should last as long as other slid state chips - but problems are reported here daily. If you can give any details of possible reasons please do.Due to the unprotected contacts, I would opt for electrostatic discharge - from acrylic clothing.
You should be able to recover at least half of the recorded data, but I make no promises if any can actually be recovered.
Posted on Jul 20, 2008
  • 74 Answers
SOURCE: Sony Cybershot DSC-P200 Get error message
have you tried formating the card and camera
to format the card insert itinto card reader and go to my computer right click on the drive then select format and follow the instructions this should solve the problem
also try reseting the unit at the same time by following the onscreen instructions in the set up mode
Posted on Sep 12, 2008
Techlevis
  • 8 Answers
SOURCE: Memory Card Error after Formating memory card
instead of quick format, use the full format.  Then put back in your camera and format again with the camera.
Posted on Mar 18, 2009
old marine
  • 2122 Answers
SOURCE: Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
Posted on Apr 22, 2009
Tip
How to Recover Lost Photos and Video from Canon PowerShot SD780 IS
<span> <span><img src="maggiena_8.jpg" /><br /></b></span>Canon PowerShot SD780 IS</b> may be the slimmest Digital ELPH Canon has ever created with dimensions 2.10" h x .70" w x 3.40" l, .26 pounds and 2.5 display size. It captivates the senses with bold saturated colors and a daringly original design that matches the intensity of Canon's most innovative camera technology.</span> <span><br /></span> <span><span> <p>Owning to its wonderful picture quality as well as high resolution, it becomes the first choice for many photographer lovers. One more reason that it turns out to be so popular is it supports various standard storage media like SD/SDHC, Multimedia Card, MMC Plus and HC MMC Plus memory cards</b>. images, Video and other multimedia file like songs can be saved there. Usually, keeping a backup of data like pictures and other multimedia files is recommended at the very beginning in case the data was lost by mistake in the process of using the camera. However, if you forgot to backup, you have to use a third party program to <a href="http://www.card-data-recovery.com/">retrieve Canon PowerShot SD780 IS data</a>.<br /> <p><br />Cases about losing data</b><br /> <ul> <li>1. When connect Canon PowerShot SD780 IS to your computer and being transferring vocation photos from SD card to computer, accidently your camera shut down due to low battery. After change the battery and restart camera again, you may encounter the error message "memory card error" that means the memory card is inaccessible.</li> <li>2. While reading data or writing data to SDHC card, "I/O device error" occurs and all photos and video miss.</li> <li>3. On the process of shot, message "memory card is full" pops up to you. However, after deleting some pictures, it shows the same result.</li> <li>4. Connect your SD card reader to computer, the window pops up with message "you have to format SD card before using it". After formatting SD card, all your pictures and video lose.</li></ul> <p>Resolution</b><br />If the above phenomena happen, don't panic, lost photos and video in Canon PowerShot SD780 IS are recoverable. First thing to do is stop using camera to shot for fear that the data was overwritten. For the first two cases, make sure the SDHC memory card is properly inserted. If it still can't be recognized, try to use a card reader to connect it to PC. Or else you have to format memory card and use effective photo recovery software to get back lost photos. For the last two cases, you should rely on <a href="http://www.card-data-recovery.com/">Canon PowerShot SD780 IS picture recovery</a> program. There are many effective Canon digital camera photo recovery program available in the internet, just choose the perfect one for your camera. <br /></b><br /><br /></span></span>
on Jul 20, 2011 | Cameras
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
Canon FE-370
You can recover pictures from canon camera with camera recovery software, download this one names asoftech photo recovery that helped me before
http://www.asoftech.com/apr/
Take note that you'd better remove the memory card from camera, and then connect the memory card to computer with a card reader.
If needed, you can do a quick format of the memory card, and then use asoftech photo recovery to recover the photos.
Here's a video tutorial for camera photo recovery
Dec 23, 2011 | Olympus FE-370 Digital Camera
I am getting a "Memory
Its a very common problem with S400,S410 and some others.
As a case study, see the following error message on the Canon IXUS 130 when trying to view some photos previously stored in the memory card SDHC
"Memory Card Error"
Every single photo stored on the memory card becomes inaccessible after the above error message. In addition, no more photos can be stored on the memory card. In short, the card can not be read or written.
Cause:
The above error message that makes all the pictures inaccessible is mainly caused due to corruption of the memory card. Reasons why you are responsible for the above error message is virus infection, interrupted read / write operation, and human error.
Resolution:
The resolution for the above error message is the format of memory card into the camera. The process erases all data previously stored and allows you to save the new data. While the format is a good resolution for users who do not require the old data, it is fatal to users such as photographers, detective agencies, etc, to save critical data on your memory card. However, the formatted data recovery day is now an easy process. It is therefore necessary to use an advanced part of third parties. A tool for image recovery is readily available on the Internet by one click.
Data Recovery is an application of high-end recovery that recovers data from almost all formats SDHC Card, XD and MMC. The read-only photo recovery tool also allows you to restore data in the defined location. The software runs on Mac OS X and Windows.
Check this link for additional details: Simple Fixes for SD "Memory Card Locked" or "Memory Card Error"
Hope helps.
Jun 07, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
I have sony cybershot model DSC-HX5.one fine day i click many photos of my friend party then later when i came home inserted the memory card in my laptop and go to see there are no photos found in the...
Vikram, first of all take no more pictures with the memory card. You'll need to use recovery software to recover your photos. There are very many freeware options for your to choose (here's a short listing with reviews). You'll need to use your computer's card reader with this software. Now AFTER you've recovered your photo's, you'll need to initialize (format) the card in your camera (DON'T use your computer to initialize the card). This will erase the card, but it will also help prevent this instance from reoccurring. Look in your camera's menus for the format option.
Jun 05, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Canon Power Shot A480 memory card error showing on screen I have checked side locked button
If it's a brand new card, it needs to be formatted with the camera. If it's been used before, the files may have been corrupted when plugged into your (or another) computer.
Nov 08, 2009 | Canon PowerShot A480 Digital Camera
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
Camera Memory Card Error, Canon Power Shot A520.
It sounds like your card is the problem. Try using a different card in your cam to confirm this. You might try to format the card (should be a menu that lets you do this) to see if that helps. Also check the connectors on the card and make sure they are not dirty or broken.
Mar 06, 2007 | Canon PowerShot A520 Digital Camera
Cameras Logo
19 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
