Question about Dishwashers
Dishwasher I'm not sure how I would tell if a button were stuck. As we stated, all was fine until the breaker was shut off and then back on again.
    Brigadier General:
  • 5,158 Answers
I'm bond by fixya policy to answer your question in the same post as it was originally made as it is a premium question. give me a few minutes and i'll do my best to find the method of testing the keyboard. i need to find the original question first.
Robert
Posted on Sep 22, 2008
  • Roberta Smith
    Roberta Smith Sep 22, 2008
    i have found more information on the machine. it's going to take me a few minutes to wade thru all the information but i'll post a condensed version of a possible solution to your problem as soon as i can.
    Robert
How do I over ride power button, force shut down
The dishwasher has detected a leak, and is trying to drain all the water out of the dishwasher. The problem is that the water has leaked into the base of the dishwasher, and the drain pump doesn't drain water from there! You dishwasher probably has a 1 or 2 lights on (or flashing), which also, when decoded, would indicate a leak. Basically, you have to pull the dishwasher out and sop up and dry up all the water in the base. That will stop the drain pump from running, but you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose. Good luck! If this sounds like more work that you feel qualified to do, I recommend you call a professional repairman. For Samsung dishwashers, I recommend calling Sears.
Aug 26, 2014 | Samsung DW80F600 24" Black Built-In...
My dishwasher was working fine until last evening when my daughter opened it during the rinse cycle. I can't get it to start up again, it is just dead. i checked the curciut breaker and thats ok. Is there...
If the unit won't start and there are no signs of power make sure you're dishwasher is getting power. If so then likely you will need a new fuse which if you go to the link below, you can download a video to show you how to replace the fuse on your dishwasher.
http://www.appliancerepairlesson.com/shop/dishwasher-videos/control-repair-whirlpoolkitchenaidkenmoremaytagjenn-air-amana-dishwashers/
Good luck
Feb 04, 2011 | KitchenAid 24 in. KUDM01TJ - Multiple...
How do you reset the whirlpool gu2400 xtp83 dishwasher. the clean light is flashing. The unit will not start
Can be caused by detection of a heater circuit problem. You can reset by running the diagnostic cycle. To turn of the diagnostic cycle, press: HEATED DRY button, then NORMAL button, HEATED DRY button again, then NORMAL button. The cycle runsfor ~22 mins. When it completes, the blinking light should go out. You can then try running the dishwasher again. If the problem comes back, the heater element or Thermister may need to be replaced
Jul 29, 2009 | Whirlpool GU2455XTS Built-in Dishwasher
Will not start. control stuck on glasses cycle. display states "39" cannot change cycle or cancel
Go to the fuse pannel and trip the fuse breaker off and then put it on again. It will reset the automatic cycle. Vitally
May 13, 2009 | Frigidaire PLD4555RFC Dishwasher
Power outtage blues
Hello daniedag,
Unfortunately, your dishwasher may have experienced a power surge when the power went off and dmaged some internal components or the control logic. There is no way of knowing the extent of your problem without a thorough diagnostics to it. It could be something as simple as a circuit borad component, stuck relay but this kind of repair is probably not something you would want to tackle yourself unless properly trained and with the proper test equipment. If you have homeowners insurance, it may cover the damage.. If not, then a service call is most likely required. Here is a link to the GE website for yopur dishwasher but your model is not PWD9200 and IS PDW9200 http://genet.geappliances.com/DocSearch/Dispatcher
Hope this helps..
Regards,
Rick
Dec 13, 2008 | GE 24 in. Profile PDW9200J Built-in...
GE Max dishwasher no lights on panel
I have the same problem and actually found a workaround by mistake you may try as a temporary solution (if that works for you):
- press and hold the lock button for a couple of seconds
(the delay timer would increase by 1 hour)
- press and hold the lock button again
- repeat until it reaches 9hrs
- repeat one more time: the control panel should be functionnal again.
Let me know if that worked for you!
Feb 04, 2008 | Dishwashers
Dishwasher not working again
is the clean light blinking, if so make sure water temp is at least 120 degrees
Jan 02, 2008 | Kenmore 24 in. 15933 Built-in Dishwasher
DISHWASHER WILL NOT POWER ON AND THERE IS POWER TO THE OUTLET
more than likely the door catch switch or the on off button, check these 2 first
Oct 13, 2007 | GE 24 in. PDW9880LSS Stainless Steel...
Dishwasher's "Pot-n-Pans" light flashing
ga, behind the toe panel on the bottom there should be a tech sheet explaining how to put the dishwasher in the test mode. See if you can enter the test mode. If you can't, you probably have a stuck or shorted keypad. Catriver...post back
Mar 03, 2007 | Kenmore 24 in. 16009 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
