Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA34 washing machine
Hi. Someone's managed to depress the start button for this so that it has sunk back completely.
I wanted to know if the front panel can be opened and i could re-slign the button (i'm presuming it's sprung from behind)
Any help would be appreciated.
Thanks
Mandy
  • Hotpoint Master
  • 3,463 Answers
Remove top cover, 2 screws are hidden behind 2 plastic covers at front of lid, push the lid back to remove , undo the screws that hold the dispenser, and slide the console panel to the right, then you can access the control board and reset the button,
Posted on Jan 04, 2009
Hotpoint WMA34 machine nasty smell ? partial bloc
Hi if you pull your machine out so you have access to rear then you can remove the bottom panel using a screw driver. This will then give you access to the sump pipe, using either a pair of grips, or screw driver/ depending what fitting you have, you can remove the clip holding the sump hose in place,You may find that this is where you are likely to have a blockage.be sure to place the ball back into place after as this acts as a non return vaulve. while you have this pipe off it may be worth just taking the pump side of the pipe off to ensure the pump is clear.Also make sure all pipes are on secure when replacing clips.
Feb 16, 2010 | Washing Machines
Hi, my hotpoint aquarius extra washing machine wma34 drum has stopped turning it is 7 years old. there is power and the water is still going in and draining out but it will not turn. please help.thankyou.
Remove the lower back cover, check to see if the belt is o/k.
If belt o/k,then remove the motor and check the brushes in motor..
If less than 3 or 4 mm long, then they need to be replaced.
Hope this helps .
Jan 06, 2010 | Select Brands Washing Machines
Hotpoint aquarius wma34 washing machine - flooding and clicking
Sounds like it could be relatively expensive to put right.
Personally, I think you would be better in investing in a new washer, more so in view of the fact that is 7 years old.
There are numerous possibilities for the symptoms you describe.
Hope this helps you to come to a decision.
Dec 29, 2009 | Washing Machines
No manual
HI. i have located the manual and you can access it via the link below. You can also print it out if needed.
CLICK HERE FOR THE HOTPOINT MANUAL.
Please rate and god bless:)
Apr 03, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Aj nide instruchyn HOTPOINT WMA34
Hi.
Log onto -www.hotpoint.co.uk
Then click After sales service,then download user manual.
You can then view this on screen, or print it off.
Please leave feedback.
Nov 01, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius WMA34 not progressing through wash cycle
hi
iwould think it is the programer may have failed mechanically not moving on
cheers
grant
Oct 23, 2008 | Washing Machines
Door lock light flashing
WASHDOCTOR
Rank:guru_s.gif Guru
Rating: 87%, 146 votes
IF you machine is a wma39 not a wmm39a then what has happed is that you control board is blown basically.
TO check this remove the soap draw and you will c three screws remove them... TO make removing the panel easier i would suggest removing the top as well as the front panel is wedged into it.. Then unclip the board from the panel and you will c where the big wiring plug is attached that the tracks on the board are blown.. There is no point replacing the board untill you can work out what has caused it to blow because it will blow again.. Its usually the motor or the doorlock which blows the board.. Trust me i been dealing with this type of machine for years...
Apr 29, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
there is a small access panel in all front loaders.  there is probably a coin stuck in the compartment.  this will stop the water pump operation correctly
Oct 27, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA34 Where to find the motor to change the brushes
DON'T FORGET TO UNPLUG THE POWER FIRST!
Remove the lid and the motor is sat to one side on top of the drum.
Oct 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
310 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
