Question about Abit AV8-3rd Eye Motherboard
ABIT AV8 not reading SATA ASUS DVD Burner
I have the ABIT AV8 motehrboard and am running one SATA hard drive on channel 0 and an ASUS SATA dVD burner on channel 1. My rpoblem is that even though the DVD drive shows up under "My Computer," it won't read any disks inserted unless I reboot the computer. I don't have extensive knowledge of SATA and RAID configurations, so any help in resolving this matter would be appreciated.Thank you.
  • oren_b Jan 28, 2009
    I have a similar problem with the AV8 3rd Eye and an Asus DVD burner. It takes ages to load DVD's and even when it does it sometimes disappears from the device manager. Have you managed to solve your problem?
  • trg4456 Mar 02, 2009
    I did manage to fix the problem. the issue was in the registry. I was using some software that changed the value sin my registry, causing my drives to not read properly. I know what you mean with the lag using SATA with this motherboard. I have just learned to live with it since everything else is functional now. If I can remmeber where I found hte fix, I'll post here for you.
I solved this differently - I just connected the drive via a USB-to-SATA adapter and all is well. I guess my motherboard's SATA controller can't handle modern SATA2 drives properly. The USB adapter did the trick.
Posted on Mar 02, 2009
  • 80 Answers
You should contact your computer servicing centre.the problem might be of the drive.for getting more knowledge about the ASUZ mother board and SATA please make use of your users CD which is given with every ASUZ motherboard.easily understandable pictorial reprasentation of the whole mother board are given that you can even find out the problem in *********** board if any. if you are convinced please rate me
2 Suggested Answers
  • 2351 Answers
SOURCE: I have a abit 1c7g motherboard intel 3.2ghz
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary".
Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices.
Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below;
Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Posted on Jun 27, 2010
When trying to finalize DVD disc, why do I often get error E 22 Cannot record on this disc (DVD-R)?
I don't know what means error E22 but if you start experience frequently the record errore your burner is failing. Check connections in your computer, specially the data cable if you are using SATA. Use cables with a "clip" so your connection should not get loose.
If everyting is right and you still can't finalize correctly your recording, change your DVD burner
Internal DVD Drives
ASUS External 12X Blu Ray Burner with USB 3 0 BW 12D1S BLK AS Black
Amazon com Blu ray Drives Electronics
7 Ways to Solve CD and DVD Burning Difficulties CDs and DVDs
Sep 09, 2015 | Televison & Video
ASUS 22x Internal CD/DVD Burner not working
Look into the little jumpers on the back.
If its SATA its np But if its IDE you need to set the jumper to master or slave or cable sellect.
May 01, 2012 | ASUS 22x Internal CDDVD Drive Burner
I CANNOT LOAD WIN7 I cannot get my system to boot from a CD disk (Win 7 Ultimate) I set the BIOS to boot from a CD device - the priority is set for CD first. All other values are default. In...
try to reset bios if does't work try using a usb dvd drive (external dvd drive) remember you do not will be able to read a dvd CD(WINDOWS 7 CD) using a cd burner.
you will need a dvd drive.
Feb 07, 2011 | ASUS Computers & Internet
My computer restars while nfs shift on max settings games config : 9600gt, asus p5k, 4 gb ram, 3 500gb hd, 1 sata lg cd dvd burner
Hi, if your computer restarts this means that your computer lacks of a running 3 hard disks drives ?? + 4 dvd writer ..try to unplug a hard disk the dvd drive and unused usb devices and see if your computer can handle playing on maxed out setting if yes then upgrade your power supply unit for a 550w ;) enjoy
Jan 17, 2010 | ASUS Computers & Internet
How 2 install in my new hp also have a burner on same cable burner works but both dont work 2gether
a dvd burner on same bus as a hard drive..the cable needs to go to hard drive first then the dvd that the case? also, if it's SATA, the order on which cable comes from the board to hard drive SATA 0 is critical
Dec 06, 2009 | Maxtor (6L250R0) 250 GB Hard Drive
Cannot get sata drives reconized on my abit av8 motherboard.
i required mother board drivers for asus
Jun 09, 2009 | Abit AV8 Motherboard
How do I connect Burner to IDE cable?
Yeah its a SATA and you need a SaTa controller to put into your computer you cannot connect this via ide
May 23, 2009 | ASUS DRW-2014L1T DVD-RAM Burner
DRW-1814BLT compatibility with IDE hard drive
put hard drive as Master. dvd rw as slave!
if DVD comes with sata then just put hard drive as master.
configure it on the bios setting!
if it still don't detect it
try replacing IDE cable and sata cable!
Nov 15, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
Abit AV8-3rd Eye Motherboard Logo
412 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
