Question about Dell F3534 Touchpad
Dell I1720 Touchpad will not save settings. every time I reboot I have to manualy bump up the touchpad speed.
  • 1 more comment
  • Anonymous Mar 14, 2009
    the provided links are dead. please fix.
  • Siegmund Baptistella May 21, 2009
    I have allready installed this driver version (7.1.102.7) and have the same problem.
    Siggi
    On my DELL 1720 Touchpad, the settings are not stored after reboot the system. I use the driver version: 7.1.102.7
    Siggi
    Scholar:
  • 155 Answers
Click this if your computer runs on windows vista or this if it runs on windows XP. Run the file to update or reinstall your touchpad driver. Reboot when prompted and readjust the touchpad settings. Restart to check if the settings are kept.
Posted on Nov 04, 2008
Cursor problem
Disabling the touchpad on a Dell Inspiron can be useful when typing for long periods of time, or using an external mouse. Bumping or tapping the touchpad while typing can cause cursor jumping and unwanted results. Use the touchpad software to enable or disable touchpad controls. Download the driver for your touchpad at the Dell Support website.
Click on the "Touchpad" icon in the task bar. If the icon doesn't appear, you can download and install the driver for the touchpad from the Dell website, or choose "Start" and "Control Panel." Choose "Device Select" on the touchpad menu, or choose "Mouse" in the "Control Panel" menu and "Device Select." Click "Disable" under "Touchpad" to turn off the touchpad, or click "Disable Touchpad/Pointing Stick When a USB Mouse is Connected."
h
Feb 28, 2013 | Computers & Internet
Dell Vostro 1510 (Win 7) - Can't enable/disable the Touchpad
There is an option to disable the internal touchpad when you connect and external mouse. Please check the screenshot attached.
May 06, 2017 | Dell Vostro 1510 Laptop
Dell inspiron 1545 mouse pad not working
You need to install the Dell touchpad drivers and application from the Dell support website to access the properties. You can download the drivers from the link after you select the correct Operating system version: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRON1545&os=WLH&osl=en&catid=&impid=. Save the file on desktop and right click on it, to Run as Administrator. Install the drivers and reboot your system. Now you would be able to access the Touchpad properties from the Mouse properties in Control Panel.
Feb 19, 2010 | Dell F3534 Touchpad
I have a dell insipron 1545, the mouse keys below the touchpad have stopped working in normal mode but will work in safe mode. I have Windows Vista
It seems to be a conflict with Touchpad drivers. For once, you can try a System Restore to resolve this issue. Else, you need to install the Dell touchpad drivers and application from the Dell support website to resolve this. You can download the drivers from the link after you select the correct Operating system version: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRON1545&os=WLH&osl=en&catid=&impid=. Save the file on desktop and right click on it, to Run as Administrator. Install the drivers and reboot your system. Now your Touchpad should work normally even in safemode.
Oct 23, 2009 | Dell F3534 Touchpad
Tochpad Right button do not function.
If the laptop is less than a year old then it maybe able to be repaired under warranty.
The touchpad contains electronic components just like a mouse, and a fault could develope like any electronic device.
First thing, go into the BIOS configuration and set the BIOS configuration back to the default settings, then save, exit and reboot the laptop.
If this doesn't fix the problem then connect and use an USB mouse instead of the touchpad.
Aug 19, 2009 | Dell Inspiron 1420 Notebook
Dell studio 1737 mousepad not working
You can try the steps below and this definately should fix the issue.
Download and install the latest touchpad driver:
Uninstall the touchpad driver:
1. Click the Start button, point to Settings, and then click Control Panel.
2. When the Control Panel window appears, double-click the Add or Remove Programs icon.
3. Locate the software for your keyboard or mouse in the list below.
• Microsoft IntelliPoint software
• Logitech software
• DellTouch software
• Synaptics software
• Alps software
• Set Point software
4. Click to highlight the device name and then click the Remove button.
5. Follow the prompts to uninstall the input device driver/software.
Download and Install the Latest Touchpad Driver Available:
Please follow the link below to install the latest touchpad driver.
http://tinyurl.com/5k9tth
1. Locate “Input device drivers” and click on (+) sign next to it.
2. Select “Touchpad”, click Download Now. You may receive a warning and an option to run or save the file.
3. Click Save.
4. When the Save As window appears, designate a folder (desktop) to save the file that is being downloaded, and then click Save.
5. When the download is complete, go to desktop and locate the same file.
6. Right click on it and run as administrator.
7. Click on allow and follow the simple instructions to update the touchpad driver.
Please do not forget to rate the solution.
Regards,
Musheer.
Jun 12, 2009 | Dell Studio 1737 Laptop
I have dell inspiron 1525, the left touch pad key is not working..i did sray some dust remover spray thinking it might be a dust issue..it did work after that for couple of hours but then stopped...
You can try the steps below to fix the issue.
• Logitech software
• Alps software
http://tinyurl.com/3vlce4
3. Click Save.
Regards,
Musheer.
Mar 16, 2009 | Dell F3534 Touchpad
Dell touchpad needs resetting every boot up
You can try to update or reinstall the touchpad driver. Click this and run the file. Restart when prompted. Try adjusting it again and see if the settings are retained.
Nov 02, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
1,257 people viewed this question
Alun Cox
