Every time that I try to print, the service error 5700 comes up. It tells me to check printer. I have to troubleshoot until it works again. I reset it than shut off and restart or occasionally restart the whole computer. Any suggestions?
  • Binny7711 Sep 22, 2008
    Thank you very much.  I have tried that in the past and it works most of the time but unfortunately not all of the time.  Take care.
    Scholar:
  • 152 Answers
It could be a loose cable or loose connection. Try to fix all connections. Make sure all pins are firmly inserted.
Posted on Sep 22, 2008
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
Error 5700 is showing up on my printers display and i cant get rid of it so it won't let me print,scan,fax or photocopy. I've turned it off and on, cleaned it out but still no luck
Error 5700 is a paper feed or paper sensor malfunction error: make extra sure that you do not have any jammed piece of papers in your paper feed/roller mechanism.
If you tried turning if off and UNPLUG from AC main for a few minutes and it has not reset the printer, try the 'soft' reset by holding the ON/OFF switch down for say 5 seconds after the screen goes blank, then release the ON/OFF button and let stand for a couple minutes before powering up again.
If it does not work, call the Canon Help desk for further assistance!
Jan 07, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Alarm light flashes, and I can't print anything. a box comes up on my computer screen that says Service Error 5700..to cancel the printing and push OK on the printer. Nothing works!
First allow the printhead to cool down. Disconnect the USB cable, plug it back in. Turn the printer on and off and check for any obstructions or paper jams. (Look specifically along the print head path.)
This error usually indicates a problem with the paper path (or pick up) for Canon Printers. There is a guide that needs to be exactly positioned relative to the chassis and it can come loose. Servicing this is complicated - you need to remove the sides and the bottom of the printer then check the guide position. Finally you disconnect the Logic board and loosen mounting screws. Reset the guide and reassemble the printer. (You will need a detailed set of pictures for the positions and I don't have one for this printer.)
Canon recommends you send the unit for service if there first set of solutions do not work. (That's the check for obstructions section.)
I wish that I could be of more help.
Jun 27, 2010 | Canon PIXMA MP780 All-In-One InkJet...
MP530 error code 5700
Please be sure you do not have a paper jam. Bits of paper can be left internally which may impede the paper path.
Otherwise you may try to reset the device:
1) Press and hold the <On/Off> button until the display on the machine goes blank. (If this is unsuccessful, unplug the power cord).
2) Wait approx. 10 seconds and power back on. Wait until the printer completes its startup routine before trying another print job.
3) Your MP 530 requires repair service.
Dec 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error E42
Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Or try:----------------
TRY THIS STEPS... Reset Counter Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
Aug 30, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error - printer part are at the end of service life, see printing
I have had a R300 for a while now and had a few cartridges in it. Recently a message came up on the screen 'parts inside your printer are at the end of their life' and the printer refused to work!
After searching the web it appears to be a waste ink counter, but I could not find any info on resetting it.
So I tried pressing different combinations of buttons on the printer and success.
Press and hold 'stop' 'maintenance' and 'power' buttons for about 10 seconds, a message will come on the screen saying counter is reset and to turn off.
Thats it turned my printer back on and all works fine again.
I hope this helps R300 owners out!
Feb 02, 2009 | Epson Stylus Photo R300 InkJet Printer
Hello i have hp color laser jet 4700dn printer when its print from computer its s howing message 49.3048 service error how can i solve this problem .please can u advace
This is a communication error. Make sure there isn't anything in the print que. If there is try deleting it. Unhook the printer from the network or computer and try and powercycle the printer. If that doesn't work try a cold reset. Turn the printer on and once the memory starts to count up press and hold the check button until the three lights light up and release then scroll down and hit the check mark on cold reset and see if the printer comes to ready. This will reset the IP address if the printer has one
Dec 24, 2008 | Office Equipment & Supplies
Operator Error Canon i850 printer
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Dec 09, 2008 | Canon BubbleJet i560 InkJet Printer
Makes a loud popping noise and won't print
http://damnprinter.com/226/canon-service-call-errors.html this site will tell you a couple things you need to know it says a sensor error
Nov 10, 2008 | Office Equipment & Supplies
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
