New Mobo & Processor but nothing happening
I have recently renewed my Motherboard and processor as my previous one died after a power surge.
I have installed a Gigabyte s-series motherboard and dual core processor & upgraded to a new 450 watt power supply , however when I turn on the PC the cooling fans work but nothing else, not getting any bleeps, Monitor not receiving signal ( I have tried another monitor still nothing).
Any ideas on what could be wrong and how I can get it working?
Thankyou.
Regatds
Runningman
  • runningman Sep 22, 2008
    Can you explain why I need a more powerful supply as I was advised by the parts supplier that 450 watts would be fine??
    Rehards
    Runningman
  • runningman Sep 23, 2008
    The RAM is definitely compatible and what size PSU do you suggest?
    Can you also tell me why the 450 watt cant power up the mobo?
    I appreciate your help
    Regards
    Richard
    New Friend:
  • 41 Answers
You need to have a PSU greater than 450watts. that could be the problem..
Posted on Sep 22, 2008
  • Rommel Aberca
    Rommel Aberca Sep 23, 2008
    GIGABYTE’s S Series motherboard provides the ultimate dream machine for serious overclockers and enthusiasts. Making sure gamers have plenty of future CPU headroom, the GIGABYTE GA-EP35-DS4 supports Intel® Core 2™ multi-core processors as well as the all-new Intel 45nm CPUs.
    because i have some clients that has this motherboards at first we have the same problem as yours after we change the PSU into greater one.. the pc boots up make sure that your RAM is compatible to your motherboard check your RAM Frequency first. and one last thing i recommend u use a branded PSU like cool master or just search the net to find a branded PSU.. as you choose the Gigabyte S series your building a monster PC..
Asrock N7AD-SLI Motherboard LED
The fans and indicators working for a sec would normally mean that your power supply is Ok. This flash of current must trigger a switch in the mobo to start the boot process. This is not happening. The RAM is a principal player here if it does not connect the memory to the processor nothing will happen. Assuming the RAM is correct and has worked faultlessly before, remove and clean the teeth with an eraser. This prob can also be caused by the VGA card not connecting. Usually alarms sound if your mobo speaker is connected but that depends on each mobo. These are basic steps that usually start machines that have been inactive for a time or have recently been exposed to high humidity. There could be other faults...............
Aug 28, 2012 | Asrock N7AD-SLI (4711140872940)...
My power supply died (popped), so I replaced it (Antec SL350 with an Antec SL350S). However, when I turned on the switch on the back of the power supply, the motherboard powered up immediately (tower...
If you "popped" the power supply, I would check to see if the RAM might have taken a hit as well. Ram chips and CPU are sensitive when it comes to power surges. I would troubleshoot the system, unplug everything. you need monitor, power, cpu, and ram (1 at a time). Check to see if the system will POST. if you do get it to POST, start with 1 item at a time and see if the system will POST every time. If nothing happens, there is a chance you may have a damaged motherboard or cpu.
Mar 28, 2017 | ASUS A8V Motherboard
Problems with Abit NF-M2S Motherboard?
hi there..
i also have the same mobo like yours. i also thinking to upgrade my old processor with better one..
made some quick research.. i would say the mobo unable to support the new processor. checked the BIOS update n CPU support list in Abit's site..
didn't show X4 processor is supported :(
Jan 15, 2010 | Abit NF-M2S Motherboard
Upgrading the p4m900T-M2 mobo from P4 3.2Mhz to E8200 2.66Mhz
hello u must have the processor for your motherboard to work I mean the one that has been working .
with that smell of burning means the processor ur trying to ugrape was not suited for the board so pray that the motherboard is ok
have fune
bye
Sep 12, 2009 | EliteGroup P4M800PRO-M Motherboard
New Motherboard & Processor not working
Usually this symptom has to do or with memory modules with problems or the VGA adapter (integrated) could be damaged. First try to reset the BIOS of *********** taking out the battery and using the reset jumpers informed in the Mother Board manual. Then put the battery and the jumpers back to the factory default position and try again.
If this doesn't work, try to plug the power cord to another 220V as the ground could cause this type of problems.
You can also try to install another VGA adapter to check if you receive the VGA signal in your monitor.
Hope it helps...
Please tell us about your progress.
Best regards
Eduardo
Oct 04, 2008 | Computers & Internet
Replaced Mobo & Processor but PC not working
First step is to check and make sure that all cables are connected properly and that the RAM is seated properly. Also are you using onboard video or an add on card?
May 30, 2017 | Computers & Internet
Replaced Mobo & Processor Nothing Working
May I know the model of your gigabyte mobo, you just replaced your unit with.
'cause it may not be compatible with the new power suply you have upgraded with.
Thanks
Sep 26, 2008 | Computers & Internet
New Mobo & Processor but no Bleeps etc
Could be the power supply is not strong enough to power the system. Replace the power supply with one that is between 350 - 450 watts. This should provide ample power to the system.
Aug 05, 2008 | Computers & Internet
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
