Question about Canon SmartBase MP360 All-In-One InkJet Printer
I have a Canon MP360 mulitfuntion printer scanner, it scans black & white pictures/grayscale no problem at all but colour items come out with a red hue all over the picture/ Canon support have told me it needs physical repair but I am not sure it is worth the cost. Any ideas on how to fix this scanning problem? I have a canon mp360 printer and have installed new ink but the black isn't printing at all and the colour scan is just printing pink ??? Any ideas greatly appreciated. thanks,
  • Anonymous Mar 24, 2014
    Scans too dark. Colour scans streaks
DUMP IT,mine has been nothing but problems...spent fortune in inks and its hardly managed to print a thing...
Posted on Oct 04, 2008
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
My laser mfp 1815dn is reducing the size of the image of the document i am scanning. how do i get it back to scan and save a full page?
Welcome to Fixya!
Adjust the Scan setting to the defalult/appropriate resolution. See guidelines below.
Documents:
300 dpi black-and-white or 200 dpi grayscale or color
Documents of poor quality or that contain small text:
400 dpi black-and-white or 300 dpi grayscale
Photographs and pictures:
100-200 dpi color or 200 dpi grayscale
Thank you for using Fixya. Have a great day.
Jas247
Jul 12, 2011 | Dell Printers:Dell MFP Laser Printer...
Canon Pixma 3600 I want black & white printing only for documents Question: How do i turn off the colour cartridges for black & white printing only?
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Jun 06, 2011 | Canon Office Equipment & Supplies
I have an epson DX4050. I currently have a full blank ink cartridge but have one empty colour catridge and 2 other colour catridges which are running low. I want to photocopy a peice of document in black...
First, using B & W to copy a photo will cause large black blotches.
B & W are actually made up of shades of Black. To get the best quality for a B & W photo, switch to "Grayscale"
Next, is the black cartridge full? Are you using any type of refilled (absolutely worst possible choice) or a third party cartridge (second worst possible choice).
Feb 27, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Fi-5750C Fujitsu scanner can't change grayscale default setting
Photoshop is not an "advanced" scanning program. To get some "production" and value out of this expensive scanner you need a professional scanning program which also may control the settings of the scanner. Use PixEdit which utilizes the built-in jpeg compression in the scanner. Did a test scanning 10 pages A4 duplex fullcolor. Adobe Acrobat Pro used 4 minutes. PixEdit used 20 seconds. Guess Photoshop (in your version) would also scan uncompressed and not use this good scanner optimal.
Jun 26, 2009 | Fujitsu fi-5750C Flatbed Scanner
Not able to scan in colour....help
the canon ir3300 have only black & white scanner not a colour scanner, if u want to scan colour photo then go for ir 6600 or ir105 model
thks
Mar 06, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Scanning speed problem
The scanners rated speed is for black and white all error correction turned off. As soon as you start doing 24bit colour or grayscale or up the dpi the scanner will start scanning more slowly. I personally get abpout 60ppm with my error correction on black and white 200dpi. (300 dpi scans just as fast although 400dpi will slow down).
Sep 28, 2007 | Canon DR-9080C Path-Through Scanner
When printing a scanned object, paper is all gray
Whatever scanning utility you are using, set it to Black and white, not grayscale nor colour! regards, babb
May 05, 2007 | Umax Astra 610P Flatbed Scanner
Colour problem with printer
After you scan it, do you immediately print it in an image format or do you use word? If you use word i might have a tip that might help.
Before printing, click File>print>click on "Properties" and check that the grayscale printing box isn't marked, if it is unmark it and it'll print in colour.
Also anything is that, when you're scanning. After previewing your scanned piece, double check the mode, either magazine (which is in colour), Black and white or outline (i think)
That's all i have for now.
Sep 09, 2006 | Canon PIXMA MP130 All-In-One InkJet...
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
159 people viewed this question
old marine
old marine
