Question about SanDisk Sansa e250 MP3 Player
Sound only works on one side
I can only hear from the right ear plug. The connection in the player appears to be loose. Can this be repaires/
  • DiamondMD Sep 22, 2008
    When I plug in my headphones and turn on my sansa I can only hear from the right headphone. I know theres nothing wrong with the headphones because use 4 different pairs. Is there any way I can fix this??
    Problem Solver:
  • 13 Answers
First, try to use the equalizer (wich can be found in the mp3) . If it's not working, use your friend headphone
Posted on Sep 30, 2008
I have that seomtimes,i jsut go to the music eq screen and swith it between a few and it fixes.
Posted on Sep 25, 2008
I'm having the same problem, but if you wiggle the black plug at the top it sometimes fixes it
Posted on Sep 24, 2008
Make sure that the earphones are pushed in all the way. If they are not, you can often only hear through one ear.
Posted on Sep 23, 2008
Boss oethe left side of my headphone is stop working
The most common cause for this, is a loose wire connection to that speaker (as opposed to the speaker being faulty).
Has anyone pulled the cord too tight or tripped on the cord? If yes, then the internal wire connecting that speaker has an internal break somewhere.
Try the following:
1) Plug headphones into music device and turn on.
2) Gently press the wire 'in' at the left earpiece (or wiggle at the earpiece end). If sound returns intermittently, then you have n internal wire break in that end of the cord.
3) Gently press the wire 'in' at the plug where it connects to your player (or wiggle the cord at the plug end). If sound returns, then there is an internal wire break at this end of the cord.
In the case of broken internal wires, it is possible to repair.
Although very fragile, it is possible to resolder these tiny wires (you'll have to burn off the enamel coating around these wires first) back onto their respective connections, or onto a new plug.
Good luck....
Jan 13, 2012 | Bose On-Ear Headphones
Cant hear sonud on the left ear piece.right side working well.
maybe u have a fault it mite have went loose or not connected if not maybe the balance settings or it has blown? hope this is helpfull
Apr 23, 2011 | Audio Players & Recorders
Sound from 1 side only!
your ear input female jack is stripped try another new pair of earphones if not you may have to take it in for service.
Nov 05, 2009 | SanDisk Sansa E280 MP3 Player
Right earphone wont work.
It is very likely that the problem is in your MP3 player and not your ear phones. If it is still under guarentee, then take it back to where you bought it. If not it may be that the earphone jack plug is faulty? It is a trade off between the cost of repair against the cost of a new one. These things are often glued together so opening it could break it anyway - sorry
Jul 02, 2009 | Nextar MA933A MP3 Player
I cant hear the gameplay in the right ear
Have you tried using your X1 with an iPod or MP3 player? Try that, and if you hear sound through both sides of the headset from the MP3 player, then the problem is in the "Stereo Splitter Cable", which can be replaced. But if you only hear sound out of the left ear from the MP3 player, then the headset is probably broken and you should contact Turtle Beach tech support at support@turtlebeach.com.
Jun 07, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Sound louder in right Ear!
If its not something simple like a balance control in your player or a bad earbud (try a different set of earbuds w/a 3.5mm jack).
Then try this:
Theres no mention of a balance function in my Itech manual. It could be a loose solder connection on the board. Thats a common thing to happen with and circuit board mounted hardware that goes out of the unit. I.e. to your ears. Ever so slightly move the earbud jack back and forth, up and down and see if you hear static or the volumes change. If so theres 2 things to try....
First try some contact cleaner, spray it on the male jack and plug it in and out of the unit a few times for a simple try at it.
If it still has imbalance then take the cover off, for the jack side of the unit, resolder the little pins of the inside jack to the board (on the backside of the board). Or find someone that can. These units are worth a few bucks to repair IMO.
Hope this Helps
Feb 09, 2009 | Itech Blue Pro Bluetooth Stereo Headphones...
Cant hear out of right ear piece
The usual cause for that is that the headphone jack is loose or the connectors are loose inside the unit and therefore not keeping complete contact with the headphone piece. It can be repaired but would probably be cheaper to get a new MP3 if that is the sansa one.
Feb 03, 2009 | Insignia Sport MP3 Player
Sound on only one side
This is a hardware problem that happens every so often on mp3 players regardless of manufacturer. Unfortunately, the whole player will have to be replaced, b/c there is no repair svc, and no headphone jack components for sale.
Jun 18, 2008 | SanDisk Sansa e250 MP3 Player
Shure in-ear phone
I plugged the earphones in another mp3 player and they worked fine. So the interruption of sound must be in the connection between the Mp3 and earphone plug. So the earphone wiring gets a verdict of not guilty. I will do some experiments involving the female plug on the original mp3 player. That is where the problem is.
Feb 12, 2008 | Shure (E2G) Consumer Headphones
I can only hear out of one ear of my ear phones and sometimes I hear no sound at all
Perhaps you can open the player and solder the head socket it may have some dry joints there.
Jul 24, 2006 | Dell Pocket DJ MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
