Question about Digidesign MBox 2 External Sound System
Protools mbox2 issue
Hi my friend,
noticed you had helped someone out with an Mbox 2 problem so was wondering if you could help me out.
I was using my Mbox2 pro factory unit as normal but had to move my equipment to another room. I set up my gear as normal but the Mbox2 will now not work. The green LED in the top left of the front panel usually flashes as my laptop boots up and then stays solid green when it is ready to use. But now it just keeps flashing and protools will not load because it thinks the mbox is not connected. I have tried all the usual unplugging and plugging back in, loading the protools software again etc but it still just flashes. I was wondering if the problem could be the firewire connection between the Mbox and the laptop as the cable I use always comes out of the firewire port on my laptop. Sometimes the connection is lost when I'm using protools and i get an error message that I need to reconnect my Mbox 2. Sometimes just slightly moving the cable can cause the connection to break. The cable I use isn't the cable that came with the Mbox as the firewire port on my laptop is a small port whereas the mbox port is large (sorry for the lack of technical descriptions). Any advice would be appreciated. I'm not sure where to start with the troubleshooting, whether its the Mbox2, the cable or the laptop!
  • steggers Sep 23, 2008
    yes. I'm using the same power supply adapter that I always have used.
  • Nathan Ayers
    Nathan Ayers May 11, 2010
    are you using the power supply for the mbox?
    Sergeant:
  • 243 Answers
It doesnt sound like its the mbox more maybe the protools install. But as far as the cable goes can you tell me if you can ping the mbox throught the 1394 connection. If you cant ping it then damage may have been caused to the unit and it may need to be serviced. I fix my own M-box's but in my store it only costs around $50usd to fix almost all problems with a mbox2
Posted on Sep 23, 2008
Sound pops an crackels how do you change fse on mini mbox
Fuse would have NOTHING to do with the problem. Make sure to use balanced audio lines... XLR or TRS to mics or other devices.
Aug 24, 2011 | Digidesign *mbox2...
The recording level to my Mbox is very low for some reason. I am running Pro Tools LE and I have a shure 87a microphone. Every time I attempt to record a track, the input volume is incredibly low...
Make sure you turn the Phantom power on the Mbox2 on as the Shure 87A requires it being a condenser mic.Make sure you use XLR mic cables. These are just things to check on.
Jan 29, 2011 | Digidesign *mbox2...
I have a mbox2 mini and i cant find my authorization code
Then, you need to buy a code; or contact the manufacturer.
Jan 29, 2011 | Digidesign MBox 2 Mini (USB, includes...
I have a behringer xynyx 1204,and a protools personal studio,with mbox2 mini,and im just wondering if its possible to plug the mic into the mixer,instead of the mbox,and still be able to record vocals into...
It is possible, you can simply put a Y-cable for Mic or a splitter for the mbox and the Mic. You can plug the mic directly to the mixer then the other jack on the splitter connected to the mbox.
Jul 25, 2009 | Behringer Music
Mbox problem (no input,output)
i'm running os 10.5.6 w/ protools 8.0 and the original mbox. i had the same problem. protools opened and seemed to work except there was no sound from either analog outputs or headphones. this worked for me:
1. shut down computer
2. unplugged all usb cables except keyboard/mouse
3. restarted computer
4. re-plugged usb cable from computer to mbox
5. opened protools session
6. hit play and now i'm hearing sound and everything seems normal.
i hope this helps everyone else
Oct 03, 2008 | Digidesign Mbox External Sound System
Mbox 2 and new macbook pro
my Mbox isnt being found by my mac. when i try and install protools it tells me the mbox carnt be found. i have tried different usb cables ect but nothing seems to work.
Jul 22, 2008 | Digidesign Mbox 2 Barebone
Mbox 2
dkjkjd jheuj'y je
Jun 13, 2008 | Digidesign Mbox 2 Barebone
Setup
plz give solution how to driver install
May 31, 2008 | Digidesign Mbox External Sound System
Computers & Internet Logo
301 people viewed this question
Top Digidesign Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
