Question about Dryers
Duet model GEW9250PWO DOES NOT START - SENSING LIGHT GOES ON AND REAMINS ON - DRUM DOES NOT TURN.
  • foosbar Mar 17, 2009
    Did you happen to have this resolved already? I just encounter this same problem & wonder if there is any tips out there.
  • Anonymous Apr 27, 2009
    Exact same problem here except model number of mine ends in pw1.
I have a whirlpool m# gew9250pwo wiyh sensing light on
Posted on Jul 03, 2009
My Whirlpool duet dryer isn't drying on automatic or timed settings. I replaced the ther-o-mister, but the dryer isn't heating up. How do you run a diagnostic on this dryer. Model GEW9250PWO
You should know that dryer has a thermal fuse located along exhaust Of heat... When You over load the machine the flow of air is not enough... Then thermal fuse is damaged ( open due security condition ) and the flame is turn off all the time... Just replace the thermal fuse. I hope this can help You. Sincerely
Jul 10, 2013 | Dryers
Control Panel in my whirlpool duet dryer model #GEW9250PWO will come on & the dryer will not work at all. Unplugged dryer and plugged back up still doesn't come on. The light within the drum is on when...
First check for 220 volts incoming power to the dryer at the terminal block on the rear of the dryer.
If you have 220 volts,check continuity on part number 59(thermal fuse) in the attached diagram. No continuity is a bad part.
cut and paste this link to your dryer diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139909&diagram_id=951915#d951915
Jul 14, 2010 | Whirlpool GEW9250 Electric Dryer
Brand new Duet Dryer - WED9400SZ model - just installed and connected - everything looks good. BUT, it won't start. All I hear is a beep sound? any setting to be turned on?
Make sure that the door is firmly closed and the light inside the drum goes out. I have model YWED9400SW (brand new) that had the same problem. The spring lock on the top was not fully engaging. Press firmly on the top and bottom of the door until the light goes out then press start. Good luck.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Stuck on Sensing
Fixed! I opened up the top of the dryer (which can be done by simply removing three screws on the back of the unit and then sliding the top back and up) and found that the dryer belt was snapped in half. There is a belt tensioner near the motor that has a switch in it and will not allow the dryer to start if there is no tension on the belt. I was able to change the belt by myself for only $10, but it was not the easiest thing to do so calling a service shop would be recommended.
Mar 19, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool Duet Front Loading Washer Model GHW 9200 LW
what shoul I need to fix when the light sensing on and the dryer does not start ( it still hot ) .
Whirlpool dryer GEW9200LW
reply to tomagic3@yahoo.com
thanks
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer problem
You need to listen for the motor working ? Open the dryer door hold the door switch in and start the dryer . A buzzing sound may indicate a bad motor. If you hear a slight spinning noise ,it may just be the belt.
Sep 24, 2008 | Dryers
Whirpool duet dryer quit working
chould be a fuse inside dryer its oblong white ck it but unplug dryer first
Mar 21, 2008 | Whirlpool GEW9250 Electric Dryer
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
1,129 people viewed this question
Top Dryers Experts
