2001 Daewoo Leganza Logo
Anonymous Posted on Oct 13, 2011
How can I stop my ABS brakes from occasionally activating even when I come to a gentle stop. I coast to a stop, hit the brake, and the front end feels like it's gonna fall off. The sound it makes is like a bass drum going boom, boom, boom and the car feels like it's going over horizontal cracks in the road. The ABS light comes on when I turn on the ignition (like it's supposed to) and goes out after a few seconds (which SHOULD indicate a problem with the ABS system).
montehammons
Level 3:
  • Daewoo Master 5,531 Answers
  • Posted on Oct 16, 2011
montehammons
Daewoo Master
Level 3:
Answers
5531
Questions
Helped
1643016
Points
17401
You can unplug the ABS, and it will be disabled. Doesn't sound like that's the problem, though. Have your front end checked, brakes, suspension, wheels, CV axles, everything. Before it cripples you on the road.
  • Anonymous Oct 16, 2011
    I have 4 new tires, all dynamicaly balanced; had front and rear end alignment done, had oil change and lube job (to make sure all grease fittings were lubed); had new rotors and pads installed; had suspension system checked out, and PepBoys head mechanic drove car and determined that the ABS brakes was the culprit. He suggested I take it to a service center that had the correct diagnosis software to find and fix Daewoo problems.
    My son, who does a lot of work on his own cars, suggested that there might be a certain type of rotor that is specifically designed for ABS brakes. He says there may be grooves or slots that monitor the speed and wheel revolutions to determine when to apply the ABS brakes. He wasn't really sure, though.
    How do I disconnect the ABS brakes? Do I just pull the fuse? Or is there some wiring I have to disconnect? It appears that it is definitely the brakes because it only comes on when I press the brake pedal. If I take my foot off the pedal and reapply the brakes, the noise and bucking stops.
  • montehammons Oct 16, 2011
    Sounds like you're on top of it. Try pulling the fuse, first, see if that works.
1helpful
2answers
ABS & brake Wobble in Cherokee front end
I am not familiar with your ABS as to how it is fed to the brakes but I am pretty sure I know what you are talking about. It sounds like your ABS is activating which is in my case the wheel hub. You will notice a wire harness coming down to your wheels and where that attaches is usually where the problem is. (problem being if I am correct when you brake you are getting a rapid pulsing rather than a smooth brake)
1helpful
2007 GMC Canyon ABS Fault - Originally ABS Fault started when making a sharp right turn. (ABS Fault light only). Stopping and restarting would clear 'fault' until next hard right. Later, occasional metal...
id check your caliper to see if the piston is compressing all the way if not check your fluid it should be clean not brown or if you have been through large amounts of water if it has gotten into the brake system and check your bleeder valve to check if it has rotted or come lose or if you have a break in the lines or air, most likely your caliper is failing to compress.
1helpful
2answers
My abs light comes on occasionally. everything seems fine, then some times I can't stop as well as I should. It seems that the abs is kicking in & it makes ticking noises in brake pedal area. It also...
There's a service bulliten about that problem with rust build-up on the front hubs pushing the sensors out of posistion [ most common on the pickups in areas that use road salt ], it happens mostly at very low speed. The best way to find out the problem is to have the system scanned.
2003 Mercedes E320 chugging occasionally when coasting at 2-3 mph. Is this a transmission related issue or computer or brakes or other?
Might be anything, in my case was a faulty ABS anti-lock-braking system, but the ABS light went on. At 25 MPH everything turned OK, ABS light was still ON.
ABS not working right how do I turn it off
Sound like tha ABS motor needs relacement
ABS, Brake, and service 4wd warnings all came on at once. Brake fluid level checks good.
Lift up your front end, remove the tires, and spin your hub assembly. If it grinds, and doesn't spin very easily, it's a bearing. Bad bearings on chevy trucks are notorious for alerting every sensor in the front end. Start there. It can even falsely trigger your ABS to activate when it's not needed, causing your brakes not to work, and you could crash into something. I speak from experience.
1997 Saab 9000 weird ABS problems: 1. Occasionally, the ABS instrument panel light will come on without the brakes being applied and the ABS system being activated. 2. Sometimes, even though the brakes are...
have car scanned auto zone -advanced auto and some other auto stores will do this for free most likely one of your sensors is starting to go bad usually will activate at low speed under 10 mph as ur slowing down do check this problem early as abs can cause vehicle to stop longer
ABS problem
IF YOUR WHEELS ARE CLEARING THE GROUND A BRIEF SECOND THE ABS WILL ACTIVATE THE FEELING YOU HAVE IN THE BRAKE PEDAL IS NORMAL
Top Daewoo Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Daewoo Expert? Answer questions, earn points and help others
