Question about Intimus 280 Shredder
Intimus 280 shredder noise
The shredder has suddenly become much noisier, you can hear the cutting system slowing down after cutting paper.
  • 35 Answers
The 280 is notorious for buildup of paper in the cutting cylinders and strippers.
If you are technical, unplug from wall, disassemble top cover and clean all the debris. Check nylon strippers (white plastic) for damage.
Posted on Feb 24, 2009
Intimus 602. shredder goes about 2 inchs and then goes into reverse and has a flashing red light
Clean the paper shredder teeth and make sure that there is not paper caught in it and try again to shred.
Jun 02, 2017 | Intimus Office Equipment & Supplies
How to remove cabinet from intimus 405 shredder
You can get access to the shredding mechanism simply by removing the bin and turning the machine upside down.
Aug 25, 2016 | Intimus Office Equipment & Supplies
My shredder is not shredding.
quite likely the gears have stripped off as most are plastic .
May 18, 2015 | Intimus Kobra 240 S4 Strip Cut Shredder
Intimus 602 shredder not shredding
Does it run backwards? If it runes in the right direction, it should take paper. You only should use the reverse, when the machine got stuck. But perhaps it now is running back. Or something broke, so the motor is running, but not driving the mechanical parts inside.
Jul 27, 2014 | Intimus 602 CC Shredder
Shredder stops - red light off
Some shredders are great for thicker paper. If you put a thicker piece of card through, it should activate the switch located in the middle of the shred blades. The paper might be too light to push it forward. Also, if you click the feed catch beyond it's operating position, this can also stop the shredder with no lights.
Jan 25, 2014 | Intimus 280 Shredder
Red indicator light always ON mode but the unit is not jam.cannot run even paper inserted
This can be caused by more than one problem.
The bucket it not properly placed under the shredder or the safety switch is stuck or bad. I am sure there is also other reasons the could cause the red light staying on.
Nov 16, 2009 | Intimus 280 Shredder
The shredder jammed (too much paper) then stopped and won't shred. It makes a noise, but when I insert paper, it won't shred. Is there a reset button? I picked paper out of the blades with a pair of...
Chances are, the overfeed caused the teeth of the gear that operates off of the motor to break.
This is very common in less expensive machines. I don't know if OM will let you return it because I don't know there policy. Most of the time retailers will attribute broken gears to abuse, which in turn is not warranted. These machines are mainly mass produced in China and obviously are very cheap. The labor and part (s) to repair are more expensive than replacing the machine.
If you do, look for a higher quality German machine i.e. Intimus, Olympia, HSM or Dahle. They cost more but they have a nationwide service arena and parts are always available.
Mar 07, 2009 | OfficeMax 0M96431 Shredder
Intimus 702cc pilot lamp issue
Paul,
Add more oil to the automatic oiler (I'm guessing a Bijur model with a minimum/maximum line.
When it gets close to the minimum it has a feature that will not allow the shredder to run. If this doesn't solve the problem, it probably needs to be reset. I can help you do this too!
Feb 19, 2009 | Intimus 702 SF Super Fine High Security...
Paper shredder
intimus 14.90 has te drive gear bearing busted how do i change the bearing
Sep 27, 2008 | Intimus 14.90 1/4 Inch StripCut and...
Intimus 280 Shredder Logo
234 people viewed this question
Top Intimus Office Equipment & Supplies Experts
ray gallant
Lonnie Arks
Tom Chichester
Are you an Intimus Office Equipment and Supply Expert? Answer questions, earn points and help others
