Removing current cd/dvd burner from tower to replace with new one can't seem to get it out.acer tower, not real smart with computers sorry
  • madsmith Sep 23, 2008
    thanks thanks, all good now great help once again thanks regards madsmith.
  • 661 Answers
Most CDRW drives are secured using 4 screws (2 on each side) which means you have to remove both side plates of the tower to remove the drive, sometimes manufacturers use rails which "clip" the drive in place and are removed via the front instead (sometimes having to remove a retaining screw).
after that the drive is only held in place by the connected cables.
Posted on Sep 22, 2008
Hi, i from indonesia. i have acer aspire 4520. i have problem with my laptop, first time sound card not detect, but some time detect. second problem dvd-room not detect. please help me. sorry, i...
Try this for your dvd
Start the Run Command Prompt
Type in "regedit" without the parrenthesis then click ok
Go to HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters....
RESTART YOUR COMPUTER
Jul 05, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My Acer Extensa 5630EZ making noise when i put in a cd or dvd.. can I solve the problem or it has a bigger problem?? Sorry for my english, I'm just learning this language..
This sounds as though the ACER unit is defective, the CD is turning around on a spindle which is either lopsided, or is bent. To save yourself the problem, replace the drive, if this is a new drive, go to ACER's website, request a work order, and send in your drive.
Feb 02, 2011 | Acer (91.48T37.003) CD-RW/DVD-ROM (Combo)...
Hi i have towers 5 burners each. Most of the burners are failing dissc half way. It is about 5 years old. How can i fix it. Also the main rom ( i have disabled it) cuz the dvd would keep on rotating and...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall or
try using a diferent brand/type of cd-rw you may have a bad batch of cd-rw
hope this helps
Dec 10, 2010 | Tower Produplicator 7 SATA Burner DVD CD...
Can't load my burner
The CD Burner drive is compatible with your Windows XP the software version is where the problem is. You need to get an updated version of the burner program, something like Nero burning ROM or Roxie EZ CD creator.
Buddy
Corporate Computer
May 15, 2010 | Acer (99.B0112.102) CD-RW Burner
CD burner adding pauses
the programme you use to burn the cd's is obviously set to leave a pause between tracks, check the programme settings before you allow it to burn the music cd
Oct 07, 2008 | Acer Condre CD-Tracer Pro Tower 7 Drive...
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Playing vcd in acer dvd
sounds like a codec issue, try this codec pack
http://www.free-codecs.com/download/K_lite_codec_pack.htm
hope it helps
Jul 10, 2008 | Acer (91.48T37.003) CD-RW/DVD-ROM (Combo)...
How to install a dvd burner
First you shutdown your computer, then disconnect all power cords. I don't know if you have a tower or a deskpro, with the tower just slide the panel out pulling from the back, you may have to remove a piece from the front with a tower. Pay attension to how your cd rom is hooked up, I don't know if this is a combo (cd/dvd/RW) if it's a combo, if it is a combo you would have to take out the old drive and replace with the new, just pay attenion to how the old drive is hooked there should be two cords to connect to .  If there separate drives there should be an empty bay.  Let me know how your doing, and if I can assist you more.........Thanks, Heidi
Oct 19, 2007 | Computers & Internet
Nti cd & dvd maker 7
try with other dvd writeing software like nero or roxio or you can try your own nti cd & dvd maker by re-installing bye
Sep 23, 2007 | Acer Aspire 5003WLMi Notebook
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
