Question about Whirlpool Washing Machines
My mother has an AWO/D4305 front loading washing machine which has a problem with low water intake. She always has to add 3-5 jugs of water when she starts the machine and up to 12 jugs for the rinse cycle. If she does not add this water then the clothes come out stiff with soap residue. The machine is made to only take in water from the cold pipe. An engineer has visited her twice and changed "a switch" once. An engineer is due to visit again at the beginning of Oct to see why/if the problem is continuing. As far as she is concerned the problem is still continuing as she still has to add the water -- not quite what you expect from an "automatic" washing machine! Any clues as to what she can do, or say to the engineer, to ensure that the problem which is now 6 months old can be rectified? Many thanks.
4 Suggested Answers
garing
  • 998 Answers
SOURCE: AWO/D4305 Does not spin
its not hard to put in yourself if you lay it on back and work from bottom..... est. motor cost is 130 to 150 dollars
Posted on Aug 06, 2009
nandini789
  • 430 Answers
SOURCE: whirlpool A+A 5kg/1000 AWO/D4305 clean pipe
I think you are wnting to tell the message is " clean pump ". There is no such " clean pipe ". Sir, please reply me for this matter.
Posted on Sep 06, 2009
  • 6277 Answers
SOURCE: Whirlpool AWO/D4305 Washing Machine. The "Water
Providing that the tap is turned fully on AND the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs a service call ;-0(
Good luck,
John C
Posted on Mar 27, 2011
Good luck,
John C
Mar 27, 2011 | Washing Machines
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
Whirlpool A+A 5kg/1000 AWO/D4305 clean pipe light has come on what shall i do
Sep 06, 2009 | Whirlpool Washing Machines
Aug 06, 2009 | Washing Machines
MILDEW SMELL COMES FROM WASHER
. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
Jul 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
May 19, 2009 | Whirlpool AWM8163 Front Load Washer
Whirlpool awo 3761/5/s
have you checked that there is not a blockage in the outlet pipe or that it is not kinked?sometimes if the pipe is lying to low (ie creating a u-bend) this can prevent water getting in & out & so the machine interprets it as either taps off or the pump needs cleaned (this has happened to me numerous times :) )
Nov 24, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool AWO 5140 Service-Red-Blinking lamp
hiya
it could be something thats been stuck in the pump filter, usually on whirlpools these are located at the front of the machine behind the plastic kick plate on the bottom. you may need a couple of towels or old rags as there will be some water comes out of the filter when you remove it.
hope this helps
Jul 30, 2008 | Whirlpool AWM5104/1 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
