Whirlpool Front Load Washing Machine Model no: AWM8121
I recently purchased a Whirlpool Front Loader Washer for myfamily. A coin was left in the wash (a problem with 4 children).Resulting in damage to the front tub (531).
I have had the tub repaired by a commercial plastic welder.On completion of reassembly, I have faced a number of problems and waswondering if you could give me some guidance.
I have commenced the test sequence with the followingresults:
The temperature display remains blank
The drum speed LED remains on zero
The cycle LED remains on 'Drain Spin'
The test sequence appears to enter stepone only. When pressing the prewash button to advance to step three, itappears to enter step three but stops.
To test further, rapid cycle was tried with the followingresults:
The cycle takes some water (approx 2cmvisible).
The drum rotates a couple of times eachway.
After this the house mains circuit breakeris tripped.
LEDs appear to be OK as they areindicating drum speed and wash.
This appears to be an electrical problem. The onlyareas that were disconnected in the disassembly and subsequent reassembly were:
The two wires from the Motor (1200MCA 61), at the rear tub, and
The four wires at the Heating Element(240V, 531).
I labeled the wires to the heater element but my labels felloff. Could you please advise me of thecolour coding of the four wires to the heater. Is it possible that my current problems arecaused by an incorrect connection to the heater?
I would appreciate any advice you can offer
Regards
Greg
2 Suggested Answers
  • 409 Answers
SOURCE: Whirlpool Front Load Washing Machine Model no: AWM8121
hi greg,
you may be right about the incorrect wire connection, since you get no error messages on the LCD display.
go to http://www.servicematters.com/docs/wiring/wiring_main.htm and put in your model #. it will give you the electrical schematic.
you may need a technician for this one, if you don't know how to read a schematic.
Posted on Sep 23, 2008
I HAVE A WHIRLPOOL TOP LOADER MODEL 3LSR6253E01 MY WASHING COMES OUT COVERED IN LINT. I CANT FIND A FILTER ON THE MACHINE IS THERE ONE? PLEASE HELP THANKS KATE
All washing machine have lint filters to protect the pump, but they generally have quite large holes and although called 'lint' filters, they are to stop baby socks and coins getting into the pump. They are always at the bottom of the machine behind the front kick panel on a front loader or under the agitator on a top loader.
If your washing comes out covered in lint, you need to find the item that is shedding it. May also be paper tissues left in pockets. We only have one item that sheds lint and that is a bathmat. We wash it separately.
Take a look at this video.
Washer Filter Plug Kit part 285868 How To Replace
May 26, 2016 | Whirlpool Washing Machines
Where to put washing detergent in Whirlpool AWM8121?
Simply place detergent into wash ball and place inside drum on top of clothes,,,,fabric softener goes in smallest compartment in tray
Jun 20, 2013 | Whirlpool Washing Machines
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
Whirlpool front loader washer is not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool awm8143 model front loader. works fine
this could signify that you have the outlet hose to far down the outlet pipe of the machine, or if you have it plumbed in to the plumbing under the sink you could have dirty sink water flowing back into the machine
Mar 02, 2010 | Whirlpool AWM8143 Front Load Washer
hi greg,
Sep 22, 2008 | Whirlpool AWM6120 Front Load Washer
Bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Jul 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
